is there a chance a hardware timer ISR not be triggered in a busy system?
Weizzh
Postby Weizzh » Fri Jan 21, 2022 6:57 am
HI there.
I set a hardware timer work at 4000 hz. When the isr is triggered, I will read some gpio status to a buffer. When the buffer is full, send a messsge to a queue and then other tasks can do some data processing for example publishing these data through mqtt.
Well, the data I get is bad. I found some data lost somewhere. The isr seemes to be triggered less than 4000 times.
Is there any chance the isr not triggered because of other tasks?
I tried to set the isr to ESP_INTR_FLAG_HIGH, and this time the isr isn't triggered even once. Am I missing something?
hustenhabas
Re: is there a chance a hardware timer ISR not be triggered in a busy system?
Postby hustenhabas » Fri Jan 21, 2022 8:41 pm
Hello. Ive had this problem recently and it was because I was sending the Timer ISR event to a xQueue. What I did to fix it was handling the event inside the ISR and not sending it to xQueueRecive somewhere. My timer was 104 microseconds and it worked (My project was a bitbanged uart so i needed a very precise timer interrupt).
wrong example:
void timer_isr() {
	xQeueSend()
void task_loop() {
	xQueueRecive()
	DoStuff()
right example:
void timer_isr() {
	DoStuff();
if you use a task to recive the queue events it might get suspended to run other tasks. Increasing its priority was not enogth for me
Weizzh
Postby Weizzh » Sun Jan 23, 2022 6:11 am
Thanks. It worked.
I've changed the code from
void timer_isr() {
	xQeueSend()
void task_loop() {
	xQueueRecive()
	DoStuff()
to
void timer_isr()
	set_a_flag
void observer_task
	loop()
		check the flag
		xQueueSend
		clear the flag
void task_loop()
	xQueueRecive()
	DoStuff()
In fact, it is not the first time xXXXfromISR() functions of freeRTOS don't work as expected.
Hope these fetures can be tested thoroughly so developers can acknowledge more details.
Users browsing this forum: PerplexityBot and 8 guests
