<t>Hi,<br/>
<br/>
I've just got my esp32-c3 and need to download the esp-idf for it. my laptop already installed with esp-idf version >> ESP-IDF v4.2 -dirty for my esp32 under /esp <br/>
<br/>
1) do i need to mkdir for a esp32-c3 ? or put it into the same directory as my esp32<br/>
Appreciate any advise. Thanks.
downloading esp-idf for esp32-c3
Re: downloading esp-idf for esp32-c3
4.2 does not support the C3 so you need a new version, indeed. You should be able to either remove your current install and install the new version in the same directory, or if you want to keep both versions use a different directory; your choice.
