Setting up Development Toolchain for ESP32
wind_energy
Postby wind_energy » Tue May 23, 2017 5:38 am
1. I have downloaded the esp32_win32_msys2_environment_and_toolchain-20170330,
2. then made git clone --recursive https://github.com/espressif/esp-idf.git in under a directory C:\ESP\esp-idf
3. Downloaded the template into directory myapp2 git clone https://github.com/espressif/esp-idf-template.git myapp2
4. Exported export IDF_PATH="C:\ESP\esp-idf"
5. Then hit the make command to compile the project. make
then errors occurs:
$ make
/bin/sh: python: not fund command
make[1]: *** [/c/ESP/esp-idf/components/esptool_py/Makefile.projbuild:49: /c/esp/myapp2/build/bootloader/bootloader.bin] ERROR 127
make: *** [/c/ESP/esp-idf/components/bootloader/Makefile.projbuild:31: /c/esp/myapp2/build/bootloader/bootloader.bin] ERROR 2
Please for any advice.
Many thanks,
Pawel
kurtzweber
Re: Setting up Development Toolchain for ESP32
Postby kurtzweber » Tue May 23, 2017 6:45 am
Hi
make sure to run "minigw32.exe" (or 64) and not "msys2.exe"
wind_energy
Postby wind_energy » Tue May 23, 2017 8:17 am
I`m running msys2_shell.cmd
Regards,
Pawel
kurtzweber
Postby kurtzweber » Tue May 23, 2017 8:58 am
No, you must run minigw32.exe as explained in the guide:
http://esp-idf.readthedocs.io/en/latest ... setup.html
Check it Out
Open an MSYS2 terminal window by running C:\msys32\mingw32.exe. The environment in this window is a bash shell.
wind_energy
Postby wind_energy » Tue May 23, 2017 11:06 am
I have made everything following by tutorial.
As soon as I make this step: http://esp-idf.readthedocs.io/en/latest ... et-esp-idf nothing works..
pbl@pbl-Komputer MINGW64 ~
$ make menuconfig
make: *** No rules to execute object  'menuconfig'. Stop.
$ make flash
make: *** No rules to execute object  'flash'. Stop.
Before I`ve downloaded
command menuconfig was working :(
sintech
Postby sintech » Tue May 23, 2017 12:23 pm
You should change directory to place where you have example project or template before executing "make"
But according to your output your current dir is your home dir (~)
wind_energy
Postby wind_energy » Tue May 23, 2017 1:45 pm
pbl@pbl-Komputer MINGW64 /c/ESP/esp-idf/examples/get-started
$ make flash
sintech
Postby sintech » Tue May 23, 2017 2:05 pm
Dir where you run 'make' should have 'Makefile', for example "esp-idf/examples/get-started/hello_world"
wind_energy
Postby wind_energy » Wed May 24, 2017 5:22 am
There it is.
I don`t know...maybe I should start installation at the beginning? Remove all and then start again?
krzychb
Contact:
Postby krzychb » Wed May 24, 2017 8:28 am
Yes, this is advisable to start from scratch but following step by step http://esp-idf.readthedocs.io/en/latest ... index.html.
If you diverge from this procedure it takes extra time and effort to find out the issue and help you out.
Users browsing this forum: Baidu [Spider], Bing [Bot], Qwantbot and 2 guests
