I have a custom design using the ESP32-D0WD-V3 SoC and i'm having trouble connecting to the device over UART. I am using the ESP32-Prog programmer to try and flash the target device.
Using an oscilloscope with probes on CHIP_PU, TX, RX, and GPIO0, I can see that the data being sent over the RX line to the ESP32-D0WD-V3 is the correct packet for Synchronization. The problem is that nothing comes back on the TX line from the ESP32 to the ESP32-Prog programmer.
ESP32 TX pin not sending data
Re: ESP32 TX pin not sending data
Are you sure the ESP32 is in download mode? Is the ESP32 happy in general? (You can check that by seeing if it spits out a boot message over UART0 whenever you power it on)
I figured out that the reason the ESP32 wasn't sending data is because an external crystal is required. Once I added an external crystal to my design, I was able to communicate with the ESP32.
