[Solved] Overflow region dram0_0_seg for big project ...
kolban
Postby kolban » Mon Nov 07, 2016 7:40 pm
I am trying to compile a lot of C source files and then link them together for a large application. My goal was to create a large library as an ESP-IDF component. So far, all the compiles are progressing cleanly but at the linkage step, it is failing with the following error:
LD app-template.elf
/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/4.8.5/../../../../xtensa-esp32-elf/bin/ld: /home/kolban/esp32/esptest/apps/workspace/jerryscript/build/app-template.elf section `.dram0.bss' will not fit in region `dram0_0_seg'
/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/4.8.5/../../../../xtensa-esp32-elf/bin/ld: region `dram0_0_seg' overflowed by 267900 bytes
/home/kolban/esp32/esptest/esp-idf/make/project.mk:255: recipe for target '/home/kolban/esp32/esptest/apps/workspace/jerryscript/build/app-template.elf' failed
Somewhere in the depths of my memory I seem to remember something about the current state of our ESP-IDF environment as building code that is loaded into RAM as opposed to being kept in flash... but other than that little snippet, that's all I have.
Does anyone have experience in debugging or tweaking error areas such as this? I am using the out of the box ESP-IDF and latest app template.
WiFive
Re: Overflow region dram0_0_seg for big project ...
Postby WiFive » Mon Nov 07, 2016 10:47 pm
LD app-template.elf
Dram is data not code. Are you compiling with the jerryscript esp8266 options for low ram usage? See I told you you would run out of memory. :P
kolban
Postby kolban » Mon Nov 07, 2016 11:26 pm
When I look at the front page here:
http://jerryscript.net/
The project claims that it needs <64K of RAM and <200K of flash.
Given that (I think) my ESP32 has ~512K RAM and ~4MB of flash ... I'm missing something (I think).
What I believe I need to understand is how the ESP-IDF is generating "sections" and where it wants to put them.
igrr
Postby igrr » Mon Nov 07, 2016 11:47 pm
The way to debug such issues is as follows:
1. Increase the size of the offending memory region in the linker script
2. Link the application and examine the elf file: xtensa-esp32-elf-objdump -t -j .dram0.bss
kolban
Postby kolban » Tue Nov 08, 2016 12:04 am
Thank you guys ...
Again it was another false alarm on my part ... it seems that program I am compiling (jerryscript) wants to create a RAM heap to manage its own storage (JavaScript variables). The default heap size it wanted to allocate ... 512K. Ouch ... too much. Turning it down to a more managable size and all is now good. Here is the link to the definition in the jerryscript project:
https://github.com/Samsung/jerryscript/ ... nfig.h#L41
Ritesh
Contact:
Postby Ritesh » Fri May 26, 2017 1:52 pm
We have also faced this type of issue while adding some external source to compile into application. I have also checked ESP32 LD script and found that length of dram0_0_seg is 0x50000 which is 320 KBytes of RAM.
So, I have following questions regarding that.
1) How-much we can extend that segment? upto 512 KBytes? But with that we can use any extra memory after that and it might be system not started if we allocate that much amount of memory. Basically system needs some RAM to up and running initially. let me correct if i am wrong.
2) " Link the application and examine the elf file: xtensa-esp32-elf-objdump -t -j .dram0.bss". This is just for debugging purpose. correct?
How to prevent above error? It seems most preferable solution is to store all functions into Flash memory instead of RAM. correct?
Also, On which location of flash memory the function will be defined as we are also planning to create some custom partitions into flash memory according to flash memory which we are planning to use.
Regards,
Ritesh Prajapati
Ritesh
Contact:
Thank you guys ...
Please suggest me the solution to solve this issue and its procedure as well
Regards,
Ritesh Prajapati
Ritesh
Contact:
Re: [Solved] Overflow region dram0_0_seg for big project ...
Postby Ritesh » Fri May 26, 2017 1:59 pm
Also, some more update that there are some large arrays defined into application code which are compulsory required for my application code.
Regards,
Ritesh Prajapati
Ritesh
Contact:
Postby Ritesh » Sat May 27, 2017 11:23 am
I have tried with solution like increasing DRAM0 Segment but not able to generate binary after generating elf file.
Please find following error output
dram0_0_seg len = 0x5B000
A fatal error occurred: Segment loaded at 0x40115710 lands in same 64KB flash mapping as segment loaded at 0x40115598. Can't generate binary. Suggest changing linker script or ELF to merge sections.
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Sat May 27, 2017 2:08 pm
There is only 2 solution: use less ram or add more external ram (wrover). Maybe can move some things to iram if you are close to the limit.
Users browsing this forum: Baidu [Spider], Bing [Bot], Qwantbot and 3 guests
