How it move some of code to IRAM?There is only 2 solution: use less ram or add more external ram (wrover). Maybe can move some things to iram if you are close to the limit.
Please explain with example code.
http://esp-idf.readthedocs.io/en/latest ... alloc.htmlIf a certain memory structure is only addressed in 32-bit units, for example an array of ints or pointers, it can be useful to allocate it with the MALLOC_CAP_32BIT flag. This also allows the allocator to give out IRAM memory; something which it can’t do for a normal malloc() call. This can help to use all the available memory in the ESP32.
Thanks for quick response.http://esp-idf.readthedocs.io/en/latest ... alloc.htmlIf a certain memory structure is only addressed in 32-bit units, for example an array of ints or pointers, it can be useful to allocate it with the MALLOC_CAP_32BIT flag. This also allows the allocator to give out IRAM memory; something which it can’t do for a normal malloc() call. This can help to use all the available memory in the ESP32.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bing [Bot], Qwantbot and 3 guests
