Analog READ - Precision?
E-M-Dev
Postby E-M-Dev » Wed May 31, 2017 10:02 pm
Is there a solution for Analog READ (silicon revision 0) allready?
I'm reading 1438-1440 for 1,32V (@3.33V Supply).
No matter if floating or with pulldown, the readings are allways the same.
Basically accurate with a shift of -0.15V
Regards,
Rick
ukonline2000
Re: Analog READ - Precision?
Postby ukonline2000 » Mon Jun 05, 2017 12:09 pm
yes,me too. I'm reading IO39 for 1.71V ~1.75V(The actual voltage is 1.9V). :(
E-M-Dev
Postby E-M-Dev » Tue Jun 06, 2017 7:04 pm
Can anybody from espressif please make a statement on this problem?
Basically I don't need to measure Voltages lower than 0.15v
but I would like to be sure about what is going on there.
@ukonline2000 Currently I correct the measured values by software
and it works pretty well so far. I didnt made test readings over the full range from 0.15V-3.3V yet.
Regards,
Rick
mnemonix
Postby mnemonix » Tue Jun 06, 2017 10:35 pm
There is some non-linearity in the ADC range, see my post here: viewtopic.php?f=12&t=1045#p4636
As you can see there the linearity is much better with the -0dB and -6dB settings. But there is always a little blind spot near zero.
