StoreProhibited error when equating two pointers
hobbsac
Postby hobbsac » Fri Apr 01, 2022 2:07 am
Hello, I am using the ESP-WROOM-32 with the latest version of ESP-IDF and have run into an error. I am trying to set a double pointer in a struct equal to another double pointer. My code works fine until it encounters this line of code (it works if it is commented out) where it will cause the core to panic and say StoreProhibited.
Here is the error message:
Code: Untitled.c Select all
Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d2882 PS : 0x00060b30 A0 : 0x80088ea8 A1 : 0x3ffc7fd0
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000f9f
A6 : 0x3ffc46dc A7 : 0x00000000 A8 : 0x800d2878 A9 : 0x3ffc7f80
A10 : 0x00000001 A11 : 0x3f401440 A12 : 0x3f40136c A13 : 0x00005080
A14 : 0x3f401440 A15 : 0x3ffb32b8 SAR : 0x00000004 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffd
Backtrace:0x400d287f:0x3ffc7fd0 0x40088ea5:0x3ffc8020
Here is the line that causes the error:
Timeptr->data = tPtr;
To my understanding, StoreProhibited normally means that you are trying to write to non-existent memory, however, I have allocated memory for both of these pointers in a separate task that definitely runs before the line of code in question.
tPtr = malloc(4000 * sizeof(double));
Timeptr->data = malloc(sizeof(*Timeptr->data)*4000);
Here is the struct to show the double pointer:
struct emxArray_real_T {
double *data;
int *size;
int allocatedSize;
int numDimensions;
boolean_T canFreeData;
This could very well be just a misunderstanding of how pointers work, but any help would be appreciated.
Re: StoreProhibited error when equating two pointers
Postby Sprite » Fri Apr 01, 2022 6:07 am
You're very optimistically assuming your malloc() succeeds.
hobbsac
Postby hobbsac » Fri Apr 01, 2022 6:03 pm
How do I make sure that it succeeds? Is this a common issue with ESP32 or is it something wrong with my code?
Postby Sprite » Sat Apr 02, 2022 1:27 am
My point is that you're allocating about 48K of RAM, which is a non-trivial amount. Malloc will fail if you do not have that amount of free RAM and will return a NULL pointer. That guru meditation has all the hallmarks of you trying to dereference a null pointer (specifically EXCVADDR: 0x00000000). Hence my remark: why are you so sure that those malloc calls succeed that you do not even check their result?
Users browsing this forum: coccocbot, PerplexityBot, Semrush [Bot] and 4 guests
