ESP32-S3 I2S APLL无法启用
Moderator: Bob
Wenjing
Postby Wenjing » Fri Apr 01, 2022 4:09 pm
想请教大家一下ESP32-S3在APLL 无法启用的情况下该如何正确配置I2S总线上的MEMS麦克风的参数,比如i2s_config 和i2s_set_clk。下面是我自己的代码但是无法正确运行。非常感谢!
Code: Untitled.cpp Select all
#define CONFIG_I2S_CH I2S_NUM_0
#define CONFIG_SAMPLE_RATE 48000
#define CONFIG_BIT_SAMPLE 32 //bits
#define SAMPLE_T int32_t
#define CONFIG_SAMPLES_SHORT (CONFIG_SAMPLE_RATE / 8) // ~125ms 6000
#define CONFIG_SAMPLE_T int32_t
#define CONFIG_SAMPLES_LEQ (CONFIG_SAMPLE_RATE * LEQ_PERIOD)
#define CONFIG_DMA_BANK_SIZE (CONFIG_SAMPLES_SHORT / 16) //375
#define CONFIG_DMA_BANKS 32
#define CONFIG_I2S_WS_GPIO 4
#define CONFIG_I2S_CLK_GPIO 5
#define CONFIG_I2S_SD 13
extern "C" void init_microphone(void)
// Set the I2S configuration as PDM and 32bits per sample
i2s_config_t i2s_config = {
mode :i2s_mode_t(I2S_MODE_MASTER| I2S_MODE_RX),
.sample_rate = CONFIG_SAMPLE_RATE,
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
communication_format: i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = CONFIG_DMA_BANKS,
.dma_buf_len = CONFIG_DMA_BANK_SIZE,
.use_apll = 0,
tx_desc_auto_clear: true,
fixed_mclk: 0,
// Set the pinout configuration (set using menuconfig)
i2s_pin_config_t pin_config = {
.bck_io_num = CONFIG_I2S_CLK_GPIO,
.ws_io_num = CONFIG_I2S_WS_GPIO,
.data_out_num = I2S_PIN_NO_CHANGE,
.data_in_num = CONFIG_I2S_SD,
// Call driver installation function before any I2S R/W operation.
ESP_ERROR_CHECK( i2s_driver_install(CONFIG_I2S_CH, &i2s_config, 0, NULL) );
ESP_ERROR_CHECK( i2s_set_pin(CONFIG_I2S_CH, &pin_config) );
ESP_ERROR_CHECK( i2s_set_clk(CONFIG_I2S_CH, CONFIG_SAMPLE_RATE, I2S_BITS_PER_SAMPLE_32BIT, I2S_CHANNEL_MONO) );
kaisey
Re: ESP32-S3 I2S APLL无法启用
Postby kaisey » Sat Apr 02, 2022 2:36 am
你为什么要用APLL呢
Wenjing
Postby Wenjing » Mon Apr 04, 2022 12:07 pm
因为我不是很会配置sck和ws和ESP32的采样频率这些参数,然后就想用APLL会省事一些。我也参考了一些ESP32的库也是用的APLL,比如这个: https://github.com/ikostoski/esp32-i2s- ... 2s-slm.ino
Wenjing
Postby Wenjing » Mon Apr 04, 2022 3:34 pm
<r>问题解决了,是我自己硬件线路接错了。。。抱歉占用了站里的资源
<CODEBOX codebox="c" file="Untitled.c"><s>
Code: Untitled.c Select all
</s>
extern "C" void init_microphone(void)<br/>
{<br/>
<br/>
i2s_config_t i2s_config = {<br/>
<br/>
mode :i2s_mode_t(I2S_MODE_MASTER| I2S_MODE_RX),<br/>
.sample_rate = CONFIG_SAMPLE_RATE,<br/>
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,<br/>
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,<br/>
.communication_format = I2S_COMM_FORMAT_STAND_I2S,<br/>
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,<br/>
.dma_buf_count = CONFIG_DMA_BANKS,<br/>
.dma_buf_len = CONFIG_DMA_BANK_SIZE,<br/>
.use_apll = 1,<br/>
tx_desc_auto_clear: true,<br/>
.fixed_mclk = 0,<br/>
};<br/>
<br/>
// Set the pinout configuration<br/>
i2s_pin_config_t pin_config = {<br/>
<br/>
.bck_io_num = CONFIG_I2S_CLK_GPIO,<br/>
.ws_io_num = CONFIG_I2S_WS_GPIO,<br/>
.data_out_num = I2S_PIN_NO_CHANGE,<br/>
.data_in_num = CONFIG_I2S_SD,<br/>
};<br/>
<br/>
<br/>
// Call driver installation function before any I2S R/W operation.<br/>
<br/>
ESP_ERROR_CHECK( i2s_driver_install(CONFIG_I2S_CH, &i2s_config, 0, NULL) );<br/>
ESP_ERROR_CHECK( i2s_set_pin(CONFIG_I2S_CH, &pin_config) );<e>
</e></CODEBOX></r>
kaisey
Postby kaisey » Thu Apr 21, 2022 12:47 am
ESP32-S3没有APLL吧,数据手册里都写了没有APLL,
