ESP32-WROOM-32 Module
velmurugan7kmvs
Postby velmurugan7kmvs » Sat Apr 02, 2022 6:28 am
Hi All,
Newbie to ESP32 programming.
Accidentally programmed the application firmware bin on the memory location 0x1000 using the following command,
esptool --chip ESP32 -p COM32 --before default_reset --after hard_reset write_flash 0x1000 esp32.bin
Seem i overwritten the bootloader at 0x1000 :(
I am getting the following error from the device continuously,
flash read err, 1000
ets_main.c 371
How to i reprogram the bootloader at 0x1000. Please help.
Re: ESP32-WROOM-32 Module
Postby Sprite » Sat Apr 02, 2022 8:17 am
What SDK do you use? If esp-idf, simply run 'idf.py flash'.
allrobot
Postby allrobot » Mon Apr 04, 2022 1:53 pm
Maybe see https://randomnerdtutorials.com/getting ... ith-esp32/
Arduino is suitable for beginners
Users browsing this forum: Google [Bot], Qwantbot, Semrush [Bot] and 3 guests
