OTA and Update.h
jchastine
OTA and Update.h
Postby jchastine » Sun Jul 12, 2020 10:48 pm
Good morning/evening! I'm trying to use the Update class for OTA but am having difficulty. What I'd like to do is read the file size from a server (via sockets), read a .bin file in chunks of 4K from the network and write those chunks to the updater, then end the update process. The basic code structure is:
Update.begin(<filesize>);
while (<more bytes to read>) {
read into buffer;
amountWritten = Update.write (buffer, bytes read);
Update.end();
It looks like subsequent calls to Update.write() after the first call return a value of 0, but the first time returns the value 4096. I think I have a wrong mental model for how this works, but looking at this, it should:
https://github.com/espressif/arduino-es ... c/Update.h
Unfortunately, I can't use the web browser version...
Thanks for any insight you have.
BobLynas
Re: OTA and Update.h
Postby BobLynas » Wed Apr 06, 2022 12:15 pm
HI, I am also having very similar issues, but I believe the 4k is the size of the flash block, and the ESP32 has to erase and write this, but perhaps the first time (or couple of times) takes a bit longer, I have seen delays of a few seconds sometimes. But I am literally at the same point as you and if I can get over this and find a cure ill come back and let you know
pidloop
Postby pidloop » Fri Jun 17, 2022 3:09 am
FWIW, I was able to add OTA to my ESP32 app very easily. I already had a WiFIServer instance anyway for RESTful commands so I added one called /update. It expects a POST command sent with curl as follows:
curl -H "Content-Type: application/octet-stream" --data-binary @$BINFILE "http://PowerMeter.local:8010/upload"
The key part of the code to perform the update is the following (error checking omitted):
#include <Update.h>
char buf[4096];
int lr;
httpSkipHeader (client);	// my function
Update.begin(UPDATE_SIZE_UNKNOWN);
while ((lr = client.read(buf, sizeof(buf))) > 0)
    Update.write (buf, lr);
Update.end(true);
ESP.restart();
The buf size must be 4096, no other value works. Hope this helps someone someday. Cheers!
KhushalShah
Postby KhushalShah » Sun Sep 10, 2023 7:10 pm
I have been facing the same issue.
I have an ESP32 and I am trying to download an Arduino-compiled file - sketch.ino.bin from my nodeJS server.
Here is the NodeJS code -
const http = require('http');
const fs = require('fs');
const server = http.createServer((req, res) => {
  if (req.method === 'GET' && req.url === '/download') {
    const filePath = './sketch.ino.bin'; // Change to your file's path
    const fileName = 'sketch.ino'; // Change to your desired file name
    res.setHeader('Content-Disposition', `attachment; filename=${fileName}`);
    res.setHeader('Content-Type', 'application/octet-stream');
    const fileStream = fs.createReadStream(filePath);
    fileStream.pipe(res);
  } else {
    res.statusCode = 404;
    res.end('Not Found');
const port = 3000; // Change to your desired port
server.listen(port, () => {
  console.log(`Server is running on port ${port}`);
On the ESP-side, I have this -
#include <WiFi.h>
#include <HTTPClient.h>
#include <Update.h>
const char* ssid = "khushal";
const char* password = "123456789";
const char* serverAddress = "192.168.29.81";
const int serverPort = 3000; // Change to your server's port
const String firmwareFileName = "sketch.bin"; // The name of the firmware file to be downloaded and flashed
void setup() {
  Serial.begin(115200);
  delay(100);
  WiFi.begin(ssid, password);
    delay(1000);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  // Specify the URL for the firmware file you want to download
  String url = "http://" + String(serverAddress) + ":" + String(serverPort) + "/download";
  HTTPClient http;
  http.begin(url);
  int httpCode = http.GET();
  if (httpCode == HTTP_CODE_OK) {
    Serial.println("Downloading firmware...");
    if (Update.begin(UPDATE_SIZE_UNKNOWN)) {
      int len = http.getSize();
      uint8_t buff[4096] = { 0 };
      // get tcp stream
      WiFiClient * stream = http.getStreamPtr();
      // read all data from server
      while(http.connected() && (len > 0 || len == -1)) {
        // get available data size
        size_t size = stream->available();
        if(size) {
          int act_size = ((size > sizeof(buff)) ? sizeof(buff) : size);
          int c = stream->readBytes(buff, act_size);
          // write it to Serial
          int writtenCount = Update.write(buff, c);
          Serial.println((String)"written:"+writtenCount+" act_size:"+act_size);
          if (writtenCount != act_size) {
            Serial.println("Error updating firmware here");
            break;
          if(len > 0) {
            len -= c;
        delay(1);
      if (Update.end()) {
        Serial.println("Firmware update successful!");
        delay(10000);
        ESP.restart();
      } else {
        Serial.println("Error updating firmware");
    } else {
      Serial.println("Error starting update");
  } else {
    Serial.println("Firmware download failed");
  http.end();
void loop() {
When I try to run this code, I see that the ESP32 was able to write 4096 bytes, but after that, the Update.write() returns 0 and my code exits the loop.
What may be the possible cause of this?
Possibly any issue from the server-side code ?
antonins
Postby antonins » Thu Dec 14, 2023 7:25 am
Hello KhushalShah ,
I'm facing a similar issue, have you solved your problem ?
Antonin
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], Qwantbot, Semrush [Bot] and 3 guests
