https://mobile.twitter.com/i_grr/status ... 9638898688
Demos look nice. No live stream? Slides?
Hope someone will document the demos.
ESP32 Launch Event & Demos
Re: ESP32 Launch Event & Demos
I was there, it was all in Chinese, sorry
We'll make sure to release the demos in time. You know how it goes with demos: even if they work, under the hood they often are a rushed mess that works around all the bugs you can't fix in time... we'll need some time to make everything presentable.
Sounds good. Do you have the LCD part number that was used with the demo boards?I was there, it was all in Chinese, sorryWe'll make sure to release the demos in time. You know how it goes with demos: even if they work, under the hood they often are a rushed mess that works around all the bugs you can't fix in time... we'll need some time to make everything presentable.
Not offhand... but it's a standard ILI9341 SPI LCD, the code should be compatible with a fair amount of other ones like it as well.Sounds good. Do you have the LCD part number that was used with the demo boards?
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
