SD mount problem
Jachin
SD mount problem
Postby Jachin » Mon May 09, 2022 8:02 am
I use SPI and SD respectively according to some online example guidelines_ Connect my esp32 and SD card in MMC mode, and SD card can work normally in SPI mode_ Test program, but SD_ After MMC connection, "card mount failed" is always prompted. Then I try to pull up gpio2,4,12,13,15 and change it to "sd_mmc.begin("/sdcard", false)", but the result is still "card mount failed". Can someone help me? I want to use SD_ MMC way, because I use SPI for RFID card reading. Thank you very much!
Code: Untitled.txt Select all
* Connect the SD card to the following pins:
* SD Card | ESP32
* D2 12
* D3 13
* CMD 15
* VSS GND
* VDD 3.3V
* CLK 14
* VSS GND
* D0 2 (add 1K pull up after flashing)
* D1 4
#include "FS.h"
#include "SD_MMC.h"
#define ONE_BIT_MODE true
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if(!root){
Serial.println("Failed to open directory");
return;
if(!root.isDirectory()){
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while(file){
if(file.isDirectory()){
Serial.print(" DIR : ");
Serial.println(file.name());
if(levels){
listDir(fs, file.path(), levels -1);
} else {
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
void createDir(fs::FS &fs, const char * path){
Serial.printf("Creating Dir: %s\n", path);
if(fs.mkdir(path)){
Serial.println("Dir created");
} else {
Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path){
Serial.printf("Removing Dir: %s\n", path);
if(fs.rmdir(path)){
Serial.println("Dir removed");
} else {
Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path){
Serial.printf("Reading file: %s\n", path);
File file = fs.open(path);
if(!file){
Serial.println("Failed to open file for reading");
return;
Serial.print("Read from file: ");
while(file.available()){
Serial.write(file.read());
void writeFile(fs::FS &fs, const char * path, const char * message){
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file){
Serial.println("Failed to open file for writing");
return;
if(file.print(message)){
Serial.println("File written");
} else {
Serial.println("Write failed");
void appendFile(fs::FS &fs, const char * path, const char * message){
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file){
Serial.println("Failed to open file for appending");
return;
Serial.println("Message appended");
} else {
Serial.println("Append failed");
void renameFile(fs::FS &fs, const char * path1, const char * path2){
Serial.printf("Renaming file %s to %s\n", path1, path2);
if (fs.rename(path1, path2)) {
Serial.println("File renamed");
} else {
Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char * path){
Serial.printf("Deleting file: %s\n", path);
if(fs.remove(path)){
Serial.println("File deleted");
} else {
Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char * path){
static uint8_t buf[512];
size_t len = 0;
uint32_t start = millis();
uint32_t end = start;
if(file){
len = file.size();
size_t flen = len;
start = millis();
while(len){
size_t toRead = len;
if(toRead > 512){
toRead = 512;
file.read(buf, toRead);
len -= toRead;
end = millis() - start;
Serial.printf("%u bytes read for %u ms\n", flen, end);
file.close();
} else {
if(!file){
return;
size_t i;
start = millis();
for(i=0; i<2048; i++){
file.write(buf, 512);
Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
file.close();
void setup(){
Serial.begin(115200);
pinMode(2, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
pinMode(13, INPUT_PULLUP);
pinMode(15, INPUT_PULLUP);
if(!SD_MMC.begin("/sdcard", ONE_BIT_MODE)){
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD_MMC.cardType();
if(cardType == CARD_NONE){
Serial.println("No SD_MMC card attached");
return;
Serial.print("SD_MMC Card Type: ");
if(cardType == CARD_MMC){
Serial.println("MMC");
} else if(cardType == CARD_SD){
Serial.println("SDSC");
} else if(cardType == CARD_SDHC){
Serial.println("SDHC");
} else {
Serial.println("UNKNOWN");
uint64_t cardSize = SD_MMC.cardSize() / (1024 * 1024);
Serial.printf("SD_MMC Card Size: %lluMB\n", cardSize);
listDir(SD_MMC, "/", 0);
createDir(SD_MMC, "/mydir");
removeDir(SD_MMC, "/mydir");
listDir(SD_MMC, "/", 2);
writeFile(SD_MMC, "/hello.txt", "Hello ");
appendFile(SD_MMC, "/hello.txt", "World!\n");
readFile(SD_MMC, "/hello.txt");
deleteFile(SD_MMC, "/foo.txt");
renameFile(SD_MMC, "/hello.txt", "/foo.txt");
readFile(SD_MMC, "/foo.txt");
testFileIO(SD_MMC, "/test.txt");
Serial.printf("Total space: %lluMB\n", SD_MMC.totalBytes() / (1024 * 1024));
Serial.printf("Used space: %lluMB\n", SD_MMC.usedBytes() / (1024 * 1024));
void loop(){
E (42) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (43) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
Card Mount Failed
rpiloverbd
Re: SD mount problem
Postby rpiloverbd » Mon May 09, 2022 3:26 pm
Have you tested the SD card breakout board separately? With an Arduino?
Jachin
Postby Jachin » Tue May 10, 2022 12:12 am
Thank you for your advice. I use the SD Adapter and connect it with ESP32 like this, but it can not run SDMMC_Test successfully.
I tried to change the connect way to use the SPI method and it can run SD_Test.ino successfully. Could you help me to find out the problem, thank you very much.
SD Adapter
Connect Picture
SPI
Jachin
Postby Jachin » Tue May 10, 2022 3:00 am
@rpiloverbd
Jachin
Postby Jachin » Tue May 10, 2022 3:25 am
E (15527) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x109
E (15528) diskio_sdmmc: sdmmc_read_blocks failed (265)
E (15528) vfs_fat_sdmmc: mount_to_vfs failed (0xffffffff).
Card Mount Failed
Sometimes, it report error log like this. I don't even know why show a new kind error
rpiloverbd
Postby rpiloverbd » Sat May 14, 2022 2:03 pm
Oh, I see. Sorry, I never connected an SD card to an Arduino this way. I only used SD card breakout boards like this one: https://www.waveshare.com/micro-sd-storage-board.htm
So, I really can't say what are the possible scopes of error in your arrangement. Let's see if anyone else can suggest anything worthwhile.
Jachin
Postby Jachin » Sun May 15, 2022 7:52 am
Thank you anyway! You are so kind!
Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
