Stream Function of Arduino equivalent in Arduino
barometre
Postby barometre » Fri Sep 29, 2017 12:41 pm
I am looking for the equivalent base class Stream Arduino in ESP-IDF. As far as I understand Stream is creating a class for read only from UART buffer. How can I create equivalent function in ESP-IDF?
kolban
Re: Stream Function of Arduino equivalent in Arduino
Postby kolban » Fri Sep 29, 2017 1:50 pm
Are you programming in C++? If so, I believe that the standard library functions of C++ are available to you which include I/O streaming:
Have a google on "C++ and iostreams".
For example:
https://www.cprogramming.com/tutorial/c ... reams.html
I have successfully used these with strings and files but haven't tested yet with UART. In theory it should "just work".
barometre
Postby barometre » Tue Oct 03, 2017 1:37 pm
For example:
Thank you for your reply, I make it other way around but I dont remember now how I did it. But in the future I will make as you posted.
Thanks again
tezaman
Postby tezaman » Fri May 06, 2022 9:20 am
I am looking exactly the same stuff.
Can you share the solution for that?
tezaman
Postby tezaman » Sun May 15, 2022 11:30 am
is there anything ready to use for streaming data from uart?
nicklasb
Postby nicklasb » Tue May 17, 2022 10:07 pm
Actually I am as well. Trying to run EspSoftwareSerial which needs stream.h, and there is nothing like that in ESP-IDF.
Users browsing this forum: Amazon [Bot], Applebot, meta-externalagent and 6 guests
