ESP32 with max98357a board works. But I can't use void loop() function for other purposes
mustafaxfe
Postby mustafaxfe » Fri May 20, 2022 5:23 pm
I have been learning how to program in esp32 using arduino IDE.
I couldn't figure out how to use max98357a board with Esp32-DevKitC. I have tried "Audio.h" and "AudioTools.h" libraries but not is changed.
My first attempt was just testing voice output. My code is below:
#include "Arduino.h"
#include "WiFi.h"
#include "Audio.h"
// Digital I/O used
#define I2S_DOUT      26  // DIN connection
#define I2S_BCLK      27  // Bit clock
#define I2S_LRC       14  // Left Right Clock
Audio audio;
String ssid =     "MYCROFT";
String password = "145678abc789";
void setup() {
    Serial.begin(115200);
    WiFi.disconnect();
    WiFi.mode(WIFI_STA);
    WiFi.begin(ssid.c_str(), password.c_str());
    while (WiFi.status() != WL_CONNECTED) delay(1500);
    audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    audio.setVolume(21); // 0...21
//    audio.connecttohost("http://www.wdr.de/wdrlive/media/einslive.m3u");
//    audio.connecttohost("http://macslons-irish-pub-radio.com/media.asx");
//    audio.connecttohost("http://mp3.ffh.de/radioffh/hqlivestream.aac"); //  128k aac
//     audio.connecttohost("http://mp3.ffh.de/radioffh/hqlivestream.mp3"); //  128k mp3
      audio.connecttohost("http://vis.media-ice.musicradio.com/CapitalMP3"); //  128k mp3
//    audio.connecttospeech("Wenn die Hunde schlafen, kann der Wolf gut Schafe stehlen.", "de");
//    audio.connecttohost("http://media.ndr.de/download/podcasts/podcast4161/AU-20190404-0844-1700.mp3"); // podcast
void loop()
    audio.loop();
It works as intended but when I try to add some commands to the loop function, It stops working.
I mean if I change the loop function as below, it stops connecting to the audio stream.
void loop()
    delay(3000);
    Serial.println("Hello");
    audio.loop();
Is it possible to use max98357a with some additional codes apart from just simple audio.loop().
Re: ESP32 with max98357a board works. But I can't use void loop() function for other purposes
Postby Sprite » Sun May 22, 2022 6:19 am
My guess is that audio.loop only schedules a small chunk of audio to be played next (e.g. 1/10th of a second). In other words, if you call it only once every 3 seconds, like you do right now, you get 3 seconds of silence and 1/10th second of audio. (Maybe not even that as the audio driver may notice it's not called fast enough and just stop).
Easiest way may be to do things at the correct time rather than delay:
int last_print; //timestamp of the last time we printed "Hi"
void loop() {
    if (millis()-last_print>3000) {//was the last time we printed more than 3s ago?
        Serial.println("Hi!\n"); //Yes - print line
        last_print=millis(); //Update timestamp
   audio.loop();  //Keep on playing audio
Alternatively, you could perhaps use multiple tasks to do the audio and your main loop (look for tutorials on ESP multicore Arduino) but the audio library does need to support re-entrancy for that to work without even more complicated stuff like muxes etc.
mustafaxfe
Postby mustafaxfe » Tue May 24, 2022 5:05 pm
Hi, thanks for the reply.
It solved some parts of my issue. But I also want to set loop times of audio.loop().
For instance, if I set
audio.connecttohost(tts.getSpeechUrl("Hello, World!").c_str());
I want to hear "Hello, World! once until I set another word to connecthost function.
I figure out to set with this function
      audio.stopSong();
      audio.connecttohost(tts.getSpeechUrl("Hello There").c_str());
      audio.loop();
  audio.loop();
But it is still an infinite loop that says "Hello There".
I simply want to call audio's play function for play once.
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], PerplexityBot and 2 guests
