ESP IDF printf
alb702
ESP IDF printf
Postby alb702 » Wed Jun 01, 2022 8:24 am
Hello.
ESP IDF , Master (or 4.4) , ESP32 (ESP32-PICO-D4) .
Periodicaly (i'm do not know cause) 'printf' is no output to defaut uart, if non-constant format, i.e :
printf ("test\n"); // output: test
printf ("number %d\n", 1); // no output
char * line = "line\n";
printf (line); // no output
but,
fprintf (stdout, "number %d\n", 1); // output: number 1
'printf(CONSTANT)' is have output, maybe, because gcc replace 'printf(CONSTANT)' to 'puts(CONSTANT)'.
I'm build tcp server in project, and connect to it from terminal on PC.
All ommited 'printf' output i see in terminal.
How to prevent redirect 'printf' output?
ESP_igrr
Re: ESP IDF printf
Postby ESP_igrr » Wed Jun 01, 2022 9:06 am
Is it possible that you are overriding 'stdout' stream anywhere in your code? This would explain why printf output (which uses stdout) goes to the TCP connection and 'stderr' is still printed to the console.
If you can find the minimal code to reproduce this issue, please report it at https://github.com/espressif/esp-idf/issues and we will take a look.
alb702
Re: ESP IDF printf
Postby alb702 » Fri Jun 03, 2022 3:17 am
Thanks.
I temporary removed all my modules, excluding main.c from build in my project.
Printf have output in app_main(). Now i will add module by module to localize problem.
My modules are not change explicitly vfs , stdout, etc... but are used many SDK components.
jimmerkle
Re: ESP IDF printf
Postby jimmerkle » Fri Feb 24, 2023 11:16 pm
Many stdio libraries will buffer a printf() / stdout stream, collecting characters and sending them as a group, usually triggered by a line feed.
Try disabling stdout buffering:
setvbuf(stdout, NULL, _IONBF, 0); // Disable stdout buffering
Users browsing this forum: Applebot, Bytespider, ChatGPT-User, PetalBot and 4 guests
