Code keep reboot after ESP32 connected to external board
Rhafiq
Postby Rhafiq » Fri Jun 03, 2022 4:35 am
Hello guys,
I've got a problem where I'm testing my external board esp32 only using blinking led code, but the serial monitor shows it keeps rebooting after I connect esp32 to the external board. Does anyone know what happen? What makes it keep rebooting?
I attached the circuit diagram of my external board below
Re: Code keep reboot after ESP32 connected to external board
Postby Sprite » Fri Jun 03, 2022 5:02 am
What does your serial output say specifically?
Rhafiq
Postby Rhafiq » Wed Jun 08, 2022 7:31 am
Arduino: 1.8.15 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
Sketch uses 198834 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13248 bytes (4%) of dynamic memory, leaving 314432 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port COM5
Connecting....
Chip is ESP32-D0WDQ6 (revision 1)
Crystal is 40MHz
MAC: ac:67:b2:3d:47:04
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
A fatal error occurred: Timed out waiting for packet content
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
This is the error message I got
Postby Sprite » Wed Jun 08, 2022 7:44 am
That is not a good sign; means the ESP32 cannot communicate with the onboard flash. Does the devboard also do this when it's not in your PCB? If not, check if there is something shorting pins 16-18 or 20-22 to something; those pins must all be not connected.
Users browsing this forum: Semrush [Bot] and 2 guests
