I would like to implement Bluetooth. I have taken given example "blufi".
in the menuconfig check bluetooth enabled , yes it is enabled, compiled the code ,
flashed to my ESP WROOM 32.
Device name given in the program , mobile able to display same name.
trying to pair , not able pair .
guide me how to test this .
any point to remember before start testing .
BLE implementation
edmund-huber
Re: BLE implementation
Instead of pairing, try just connecting.
To check if it is working (independent of your program): if you have Android, try using something like https://play.google.com/store/apps/deta ... scan&hl=en to scan for the esp32, look at the service and its attributes.
thank you for your prompt response, this is working for me .
Now i would like to implement the bluetooth for iphone.
do you have any sample code for this , and detail of app which can be used to connect iphone and esp woorm32
On iOS you can use the Lightblue Explorer app https://itunes.apple.com/us/app/lightbl ... 28110?mt=8
To code your own app in iOS you use CoreBluetooth framework, maybe see this tutorial to get an idea how (ignore the Arduino side, that would be done in the ESP32): https://www.raywenderlich.com/85900/ard ... -ios-swift
Users browsing this forum: Barkrowler and 5 guests
