RS485 uart trouble (solved)
wobbletop
Postby wobbletop » Fri Jun 03, 2022 3:50 am
First time working with the ESP32 and interfacing with RS485.
I'm using this shield with a M3485 chip.
https://www.electrodragon.com/product/e ... ce-shield/
For now, I'm just trying to receive data over the RS485 interface and echo it to the serial monitor.
#define TXD 17
#define RXD 16
void setup() {
  // initialize both serial ports:
  Serial.begin(115200);
  Serial2.begin(19200, SERIAL_8N1, RXD, TXD);
void loop() {
  // read from port 1, send to port 0:
  if (Serial2.available()) {
    inByte = Serial2.read();
    Serial.print(inByte, HEX);
I'm seeing activity on the on the GIO ports but the only thing that gets sent to the serial monitor is zeros. "0000000"
The activity on the GPIO16 input looks like it's active low for some reason.
Any tips on getting this working? Is this the right place to ask the question?
Thanks!
Angle Gao
Re: RS485 uart trouble
Postby Angle Gao » Mon Jun 06, 2022 1:12 am
Don't use Serial1 and Serial2! Use HardwareSerial to define your Uart and name it to different name.
HardwareSerial RS485Uart(1);
void setup() {
DongleUart.begin(19200, SERIAL_8N1, RXD,TXD);
wobbletop
Postby wobbletop » Mon Jun 06, 2022 7:06 pm
Thanks for replying! It's appreciated.
I made some changes to the code as suggested, but I'm still just getting "0000" zeros.
HardwareSerial pump(2);
#define TXD 17
#define RXD 16
char lastByte = 0;
char inByte = 0;
int count = 0;
void setup() {
  Serial.println("Starting...");
  pump.begin(19200, SERIAL_8N1, RXD, TXD);
void loop() {
  if (pump.available()) {
    inByte = pump.read();
    count++;
  //insert CR to make output readable
  if (count >= 40) {
    count = 0;
    Serial.println("");
  //check if start of packet
  if (lastByte == 0x10 && inByte == 0x03) {
    Serial.println();
  lastByte = inByte;
wobbletop
Re: RS485 uart trouble (solved)
Postby wobbletop » Tue Jun 07, 2022 7:53 pm
Turns out the baud rate was wrong and I should have figured that out from the waveform.
I used the automatic baud rate detection feature.
#define TXD 17
#define RXD 16
char lastByte = 0;
char inByte = 0;
int count = 0;
void setup() {
  pump.begin(0, SERIAL_8N1, RXD, TXD);
  unsigned long detectedBaudRate = pump.baudRate();
     if(detectedBaudRate) {
       Serial.printf("Detected baudrate is %lu\n", detectedBaudRate);
     } else {
       Serial.println("No baudrate detected, Serial1 will not work!");
void loop() {
    count++;
  if (count >= 40) {
    count = 0;
    Serial.println("");
    Serial.println();
  lastByte = inByte;
Users browsing this forum: Baidu [Spider], Barkrowler and 2 guests
