How to make BLE client connect to only specific server
I've a BLE application (NimBLE stack), it works as expected. But now I want the client to connect to a specific server and don't connect to anything else. How can I do this? How can I tell the client to connect to a specific server?
Re: How to make BLE client connect to only specific server
What is mean by specific server. if the server expose the specific uuid, you can filter out. you can use the OOB method to filter out the desired server, you can use the mac of the device to filter it out. how do you want it?Please can anyone help ?
I meant, the server and client boots up and connects for first time. The client then stores some info about the server so that it connects to this particular server only (if there are other servers in the vicinity) next time it connects and not to some other server with same services and uuid.What is mean by specific server. if the server expose the specific uuid, you can filter out. you can use the OOB method to filter out the desired server, you can use the mac of the device to filter it out. how do you want it?Please can anyone help ?
May be store the mac address or something
The specific term is called bonding.. i thing there is the example in the esp-idf folderI meant, the server and client boots up and connects for first time. The client then stores some info about the server so that it connects to this particular server only (if there are other servers in the vicinity) next time it connects and not to some other server with save service and uuid.What is mean by specific server. if the server expose the specific uuid, you can filter out. you can use the OOB method to filter out the desired server, you can use the mac of the device to filter it out. how do you want it?Please can anyone help ?
Wouldn't bonding require some I/O capability. My device doesn't have any I/O. I've tried the bleprph and blecent example from master branch. After each connect when it shows the connection information in bleprph example the bonding and encryption was shown as 0. I've tried changing various things through menuconfig, nothing helped (mainly the options in example config and there was another option in nimble to store info in nvs, however I haven't found the later in v4.4.1)The specific term is called bonding.. i thing there is the example in the esp-idf folderI meant, the server and client boots up and connects for first time. The client then stores some info about the server so that it connects to this particular server only (if there are other servers in the vicinity) next time it connects and not to some other server with save service and uuid.
I have done long time ago, you can use just works security, if no i/o capabilities..Wouldn't bonding require some I/O capability. My device doesn't have any I/O. I've tried the bleprph and blecent example from master branch. After each connect when it shows the connection information in bleprph example the bonding and encryption was shown as 0. I've tried changing various things through menuconfig, nothing helped (mainly the options in example config and there was another option in nimble to store info in nvs, however I haven't found the later in v4.4.1)The specific term is called bonding.. i thing there is the example in the esp-idf folder
Tried that the bonding flags still remains 0. Both on master and 4.4.1 tagI have done long time ago, you can use just works security, if no i/o capabilities..Wouldn't bonding require some I/O capability. My device doesn't have any I/O. I've tried the bleprph and blecent example from master branch. After each connect when it shows the connection information in bleprph example the bonding and encryption was shown as 0. I've tried changing various things through menuconfig, nothing helped (mainly the options in example config and there was another option in nimble to store info in nvs, however I haven't found the later in v4.4.1)
I was looking at this thread https://github.com/espressif/esp-nimble/issues/14, doesn't look like I can use bonding in my scenario
@abansal22 I was finally able to form a bond, do you know how to connect to only bonded device. I the thread I mentions said something about a PR but I couldn't find any such PR
Good to hear that!@abansal22 I was finally able to form a bond, do you know how to connect to only bonded device. I the thread I mentions said something about a PR but I couldn't find any such PR
I think bonding itself means to connect with the specific device. In the bonding process, they exchange the cypto keys. So next time it is available, then it is able to find and connect it.
Users browsing this forum: Amazon [Bot], jekutin, Semrush [Bot] and 1 guest
