Cryptic MQTT client error
maldus
Postby maldus » Mon Jun 13, 2022 7:29 am
Hello everyone,
I have a project using an ESP32S2 module that connects to a remote MQTT broker with SSL encryption/authentication. I'm on ESP-IDF branch release/v4.4. It all works well most of the time except with a specific query-response procedure where the the broker publishes a command and the device must respond.
Sometimes the device fails to respond and I see the following log in the monitor:
E (297861) MQTT_CLIENT: mqtt_message_receive: transport_read() error: errno=119
I (297863) MQTT cloud: MQTT_EVENT_ERROR
I (297863) MQTT cloud: Last error code reported from esp-tls: 0x8008
I (297871) MQTT cloud: Last tls stack error number: 0x0
I (297877) MQTT cloud: Last captured errno : 0 (Success)
E (297883) MQTT_CLIENT: mqtt_process_receive: mqtt_message_receive() returned -1
I (297897) MQTT cloud: MQTT_EVENT_DISCONNECTED
The code that prints this error mostly comes from the MQTT example:
        case MQTT_EVENT_ERROR:
            ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
            if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT) {
                ESP_LOGI(TAG, "Last error code reported from esp-tls: 0x%x", event->error_handle->esp_tls_last_esp_err);
                ESP_LOGI(TAG, "Last tls stack error number: 0x%x", event->error_handle->esp_tls_stack_err);
                ESP_LOGI(TAG, "Last captured errno : %d (%s)", event->error_handle->esp_transport_sock_errno,
                         strerror(event->error_handle->esp_transport_sock_errno));
            } else if (event->error_handle->error_type == MQTT_ERROR_TYPE_CONNECTION_REFUSED) {
                ESP_LOGI(TAG, "Connection refused error: 0x%x", event->error_handle->connect_return_code);
            } else {
                ESP_LOGW(TAG, "Unknown error type: 0x%x", event->error_handle->error_type);
            break;
I'm not sure on how to interpret the reported errors. I don't know where I should look for errno 119, and while code 0x8008 is described as ESP_ERR_ESP_TLS_TCP_CLOSED_FIN in the documentation the remaining logs indicate no failure.
Can anyone help me on how to further diagnose this situation?
YJM
Re: Cryptic MQTT client error
Postby YJM » Mon Jun 13, 2022 7:44 am
I think this topic has the same issue with yours. https://www.esp32.com/viewtopic.php?p=98798#p98798. You can refer to.
maldus
Postby maldus » Mon Jun 13, 2022 8:53 am
I will investigate on why the broker would decide to close the connection. Does this mean I can ignore the other error reports (for example, the errno 119)?
YJM
Postby YJM » Tue Jun 14, 2022 2:05 am
Yes, errno 119 you can ignore it. Sometimes, it is not a error.
liuweiqing
Postby liuweiqing » Sun Oct 05, 2025 9:49 am
same error
Users browsing this forum: Baidu [Spider], Bing [Bot], Qwantbot and 3 guests
