i am a beginner for developing esp32 platform, when i proceed as list on https://esp-idf.readthedocs.io/en/lates ... -a-project ,
command make monitor does not work, give me a error "AttributeError: 'Serial' object has no attribute 'is_open'"
my environment:
ubuntu 14.04 LTS
pythone: 2.7.6
does anybody else get this error too, help me to fix it, thanks
make monitor error "AttributeError: 'Serial' object has no attribute 'is_open'"
Re: make monitor error "AttributeError: 'Serial' object has no attribute 'is_open'"
Hi liuq,
Thanks for reporting this. Ubuntu 14.04 ships with pyserial 2.6, and it looks like idf_monitor uses some "new style" APIs that were only added after pyserial 3.0.
This is a bug and we'll fix it ASAP.
Angus
Angus
Was it possible to solve it?
As Ubuntu 14.04 is End Of Life now, we decided to keep the newer API only in esp-idf.
EDIT: My mistake, 14.04 is not EOL until next year. So we will make the required change in ESP-IDF. Although please consider updating your installation to a newer Ubuntu.
If you have Ubuntu 14.04, you can make it work by running these three commands:
(This removes Ubuntu's old copy of pyserial, and installs a version from the Python package manager 'pip'.)
sudo apt-get remove python-serial
sudo apt-get install python-pip
sudo pip install pyserial
Thanks Angus. What about serial trash like:
��n߂���b��b#����9O��Ă�#�n�l;|��
����H���� � � ���n߂���b��bc����9O��Ă�#�n�l{|��
� � ����� n���� ��� ��n߂���b��b#����9O��Ă�#�n�l;|��
When I do MAKE MONITOR it happends. I try to change the clock speed, but the problem continuos in every clock speed.
DO you have another solution for that problem.
If you have a 26MHz crystal, you will need to set this in menuconfig:Thanks Angus. What about serial trash like:
http://esp-idf.readthedocs.io/en/latest ... l-freq-sel
(The default is 40MHz and will result in a baud rate mismatch.)
Users browsing this forum: Bing [Bot], PetalBot, Qwantbot, Semrush [Bot] and 1 guest
