ESP32 Pico V3 I/O expander
Jinu Vijayan
Postby Jinu Vijayan » Mon Jun 20, 2022 5:20 am
Hello, I am a student and I am trying to use tca6424a with a ESP32 PICO V3. When I upload the code for the interface and the code gets executed up to the test connection command after that it is not working the code I am using is attached below. I wrote the code in vscode using platformio.
Code: Untitled.cpp Select all
#include "TCA6424A.h"
#include <Arduino.h>
#define SDA 5
#define SCL 0
#define RESET_PIN 2
TwoWire twi(1);
// TCA6424A expander1(&twi);
TCA6424A expander2(&twi);
void setup()
Serial.begin(115200);
twi.setPins(SDA, SCL);
// expander1.begin(TCA6424A_ADDRESS_ADDR_LOW);
expander2.begin(TCA6424A_ADDRESS_ADDR_HIGH);
void loop()
// Serial.print("expander1: ");
// Serial.println(expander1.testConnection() ? "true" : "false");
Serial.print("expander2: ");
Serial.println(expander2.testConnection() ? "true" : "false");
delay(1000);
The message it is showing in the serial monitor is as folows
" expander2: [ 15][E][esp32-hal-i2c.c:142] i2cWrite(): could not acquire lock "
rpiloverbd
Re: ESP32 Pico V3 I/O expander
Postby rpiloverbd » Tue Jun 21, 2022 7:47 am
Here are some info about this error message: https://github.com/espressif/arduino-esp32/issues/834
lbernstone
Postby lbernstone » Tue Jun 21, 2022 8:20 am
If the WireScan example https://github.com/espressif/arduino-es ... s/WireScan doesn't show you an address, then you have an electrical problem. I don't have time to explain how I2C works, but I'll bet google does. You probably need some pullup resistors.
Jinu Vijayan
Postby Jinu Vijayan » Tue Jun 21, 2022 9:12 am
I used an I2C scanner program and it sows the address of the I/O expanders and the pull up for the SDA and SCL pins are done inside the library for I2C.
Postby Sprite » Tue Jun 21, 2022 9:45 am
Those internal pull-ups are 50K or so, which is way too high for I2C. Suggest you add external pull-ups; something like 2K7 should work.
Jinu Vijayan
Postby Jinu Vijayan » Thu Jun 23, 2022 6:12 am
I did that but the problem still persists.
Users browsing this forum: ChatGPT-User and 12 guests
