JTAG Interface; fails on ESP32-DevKitC-32E (works on 32U)
epsiloncomp
Postby epsiloncomp » Sun May 22, 2022 10:04 pm
I have a development system running with a ESP32-DevKitC-32U core. It has a JTAG interface on the PCB connected to the ESP32-PROG programmer. It has worked flawlessly for 6 months (Visual Studio; running Visual Micro Arduino extension).
I recently purchased an ESP32-DevKitC-32E core. It fails to connect to the JTAG interface (It does work via the USB interface). The pinout is the same. I get the following error:
Uploading 'TitanRev05' to 'ESP32 Dev Module' using 'ESP32 PROG'
Open On-Chip Debugger v0.10.0-esp32-20190313 (2019-03-13-09:57)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 0
adapter speed: 2000 kHz
esp32 interrupt mask on
****[vMicro]**** Uploading App :Error: cpu0: xtensa_write_memory (line 802): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 802): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error during upload using programmer
The uploader process failed
The uploader returned an error
Error: cpu0: xtensa_write_memory (line 802): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: xtensa_write_uint32_list: error writing to 3ff48000
in procedure 'program'
embedded:startup.tcl:480: Error: ** Unable to reset target **
in procedure 'program_error' called at file "embedded:startup.tcl", line 505
at file "embedded:startup.tcl", line 480
Any suggestions would be appreciated, Thanks, David
Re: JTAG Interface; fails on ESP32-DevKitC-32E (works on 32U)
Postby Sprite » Mon May 23, 2022 5:40 am
Are you sure there's no program in flash that reconfigures the JTAG GPIO pins?
epsiloncomp
Postby epsiloncomp » Tue Jul 05, 2022 12:52 am
This is a brand new module from Mouser Electronics. I will try again with a different module. I will program via Arduino with a running example program, which will set all the pin designations and attempt the JTAG interface.
Thanks, David
epsiloncomp
Postby epsiloncomp » Mon Nov 07, 2022 10:13 pm
I am now using a ESP32-DevKitC-32EU, as the E device is not longer available. Same error as the E device.
I would like to resolve this, as I have a new project to start soon.
The 32U device works just fine. I have two ESP-PROG; same results for both.
Error:
debug_level: 0
****[vMicro]**** Uploading App :Error: JTAG scan chain interrogation failed: all ones
Any suggestions appreciated. Thanks, David
Postby Sprite » Wed Nov 09, 2022 12:51 am
It's impossible to tell from here, sorry... if your ESP32 program for sure doesn't reconfigure the JTAG pins, this is a hardware error somewhere.
epsiloncomp
Postby epsiloncomp » Wed Nov 09, 2022 12:57 pm
I have a complete controller that the ESP32 mounts to, with a JTAG interface.
Install a ESP32 U device (ESP32-DevKitC-32U); program and debug in Visual Studio/Visual Micro. Works perfectly.
Install a ESP32 UE device (ESP32-DevKitC-32UE); program and debug in Visual Studio/Visual Micro. Fails with the above mentioned error message.
Unless the logic or pinouts have changed for UE vs U, I have no explanation.
David
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, DuckDuckGo [Bot], Google [Bot] and 2 guests
