Page 2 of 8
Re: ESP32 TFT display library
Posted: Fri Aug 11, 2017 1:12 am
by kearins
Why did you commented out call to gpio_set_level() in spi_master_lobo.c?
//gpio_set_level(handle->cfg.spics_ext_io_num, 0);
GPIO.out_w1ts = (1 << handle->cfg.spics_ext_io_num);
In this case we can't use GPIO 32,33 for PIN_NUM_DC. Maybe you have a reason to do so?
I uncommented call to gpio_set_level in 2 places and modified two defines in tftspi.c:
//#define DC_CMD	GPIO.out_w1tc = (DC_VAL)
//#define DC_DATA	GPIO.out_w1ts = (DC_VAL)
#define DC_CMD	gpio_set_level(PIN_NUM_DC,0)
#define DC_DATA	gpio_set_level(PIN_NUM_DC,1)
and successfully tested demo with definition:
#define PIN_NUM_DC 33
Posted: Sun Aug 13, 2017 1:10 pm
by loboris
Why did you commented out call to gpio_set_level() in spi_master_lobo.c? ...
If I remember well, it runs slightly faster that way..
I'll check it and try to make pins 32,33 usable. Thanks for reporting.
Posted: Mon Aug 14, 2017 6:09 pm
by nickux
Hello loboris,
would it be feasible to also display PNG images? They tend to be cleaner than JPG and much smaller than BMP.
Posted: Wed Sep 13, 2017 8:33 am
by AAAwen
Dear all,
I copied component.mk from https://github.com/loboris/ESP32_spiffs_example (components\mkspiffs\component.mk and components\spiffs_image\component.mk). But, I can't execute "make flashfs" and "make makefs" yet.
Who can help me? Thanks. :oops:
[我从 ESP32_spiffs_example 中拷贝了 component.mk 文件,但是在执行"make flashfs"和"make makefs"时仍然报错,请帮忙分析,谢谢!]
$ make flashfs
Makefile:65: 警告:未定义的变量“TARGET_CXXFLAGS”
Building mkspiffs ...
main.cpp: 在函数‘void processArgs(int, const char**)’中:
main.cpp:591:83: 错误:在 C++98 中‘args’必须由构造函数而不是‘{...}’初始化
     std::vector<TCLAP::Arg*> args = {&packArg, &unpackArg, &listArg, &visualizeArg};
main.cpp:591:83: 错误:could not convert ‘{(& packArg), (& unpackArg), (& listArg), (& visualizeArg)}’ from ‘<花括号内的初始值列表>’ to ‘std::vector<TCLAP::Arg*>’
make[1]: *** [Makefile:65:mkspiffs.exe] 错误 1
make: *** [/d/AWEN/esp/ESP32_TFT_library/components/mkspiffs/Makefile.projbuild:10:mkspiffs] 错误 2
Posted: Thu Sep 14, 2017 1:43 am
by kearins
Dear all,
Did you try this receipt?
https://esp32.com/posting.php?mode=quot ... 35#pr12567
Posted: Thu Sep 14, 2017 3:34 am
by AAAwen
Yes. I test this library under Win10.
The steps are as follow:
1) Clone the repository
git clone --recursive https://github.com/espressif/esp-idf.git
git clone https://github.com/loboris/ESP32_TFT_library.git
git clone https://github.com/loboris/ESP32_spiffs_example.git
2) Copy "component.mk" to "ESP32_TFT_library/components/spiffs_image" from "ESP32_spiffs_example/components/spiffs_image"
copy "component.mk" to "ESP32_TFT_library/components/mkspiffs" from "ESP32_spiffs_example/components/mkspiffs"
3) Modify "ESP32_TFT_library/components/spiffs_image/Makefile.projbuild"
.PHONY: flashfs makefs copyfs
4) Replace the whole directory 'ESP32_TFT_library\components\mkspiffs' with 'ESP32_spiffs_example\components\mkspiffs'
5) Execute 'make menuconfig', select 'Running on ESP-WROVER_KIT' and configure 'Default serial port'
6) Ececuting 'make clean','make flash' and 'make copyfs' are ok.
Can you help me fix the error? Thank you! :?
aclas@Lenovo-PC MSYS /d/AWEN/esp/ESP32_TFT_library
$ make makefs
$ make flashfs
Posted: Thu Sep 14, 2017 6:11 pm
by kearins
Have you got environment variable OS? Run the command:
set OS
What value will be shown on the screen?
Posted: Fri Sep 15, 2017 9:15 am
by AAAwen
Hi,kearins:
The issues were solved when I updated the toolchain. Thanks a lot for your due attention to my post.
到官网更新toolchain后这个问题得以解决
Posted: Wed Sep 27, 2017 7:43 am
by kearins
loboris,
the library does not print text by TFT_print() in esp-idf commits 845c3fb (22 sep 2017) and 050ae50 (08 sep 2017). Also there are some artefacts on screen. It looks like DMA transfer does not work correctly.
The esp-idf commit with which the library works fine is 5539bfb (07 aug 2017)
Posted: Wed Sep 27, 2017 8:05 am
by loboris
loboris,
I have the fix for that issue ready, it will be pushed today or tomorrow.
