touchRead breaking analogWrite?
lbernstone
Re: touchRead breaking analogWrite?
Postby lbernstone » Tue Oct 03, 2023 6:45 pm
If you attach that pin to a different function (ie OUTPUT), then it is removed from the touch device.
You can turn off touch with touch_pad_deinit() from touch_sensor_common.h
ryeBread
Postby ryeBread » Thu Dec 21, 2023 9:48 am
I have encountered the exact same issue, trying the following workarounds:
- temporarily disable the touch functionaliy, using touch_pad_deinit()
- Make use of touch interrupts instead of touchRead()
I think the best solution to this issue would be to get a small separate touch module - so far I haven't found a feasible code workaround.
Users browsing this forum: ChatGPT-User, PerplexityBot, Qwantbot and 2 guests
