[Solved] Overflow region dram0_0_seg for big project ...
Ritesh
Contact:
Re: [Solved] Overflow region dram0_0_seg for big project ...
Postby Ritesh » Sat May 27, 2017 6:12 pm
There is only 2 solution: use less ram or add more external ram (wrover). Maybe can move some things to iram if you are close to the limit.
How it move some of code to IRAM?
Please explain with example code.
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Sat May 27, 2017 6:45 pm
If a certain memory structure is only addressed in 32-bit units, for example an array of ints or pointers, it can be useful to allocate it with the MALLOC_CAP_32BIT flag. This also allows the allocator to give out IRAM memory; something which it can’t do for a normal malloc() call. This can help to use all the available memory in the ESP32.
http://esp-idf.readthedocs.io/en/latest ... alloc.html
Ritesh
Contact:
Postby Ritesh » Sat May 27, 2017 6:58 pm
Thanks for quick response.
I will check and let you know update or any issue while accessing it.
Regards,
Ritesh Prajapati
