ESP32-S3 ULP power consumption
Re: ESP32-S3 ULP power consumption
So I have updated to the current ESP-IDF 5.4 and started using Visual Studio Code. I have run the ULP ADC examples for both FSM and RISCV, also modifying each one with the previously discussed statements to disable the ADC from ULP. The result: In all cases the consumption is still around 50 µA (# 272023). It just seems to be like that.
That means that this chip is not suitable for ULP applications that need the ADC, which really limits its use. That is very disappointing.
The power consumption of 8 µA in the datatheet for "RTC memory and RTC peripherals are powered up" is at least misleading. And the large fluctuation of current consumtion with the ADC on between different batches (see my first post) does not cast a good light on process control, introducing a lot of risk into product development using this chip.
I want a statement by Espressif on this situation.
Can you share your code and hardware schematic?
I want to rule out ULP duty cycle (in a previous post you had "WAIT 100000..." which will increase the ULP runtime and hence average power draw) and any external factors (eg. external pullup on the same pin where a RTC pulldown is being enabled).
Sure, this is the code for RISCV.
Main Processor:
ULP:
This is the code for FSM.
Main Processor:
ULP:
This is the schematic of the board I'm using: https://www.wemos.cc/en/latest/_static/ ... v1.0.0.pdf
I have removed the RGB-LED and I'm powering the 3.3 V directly, bypassing the regulator.
Since the current drops to about 9 µA when just the single line is commented where the ADC is enabled, I am fairly certain that the problem is not on the board. The differences between the chips are coming definitely from the chips themselves. I know that because I swapped chips between two boards (one at ~20 µA, one at ~50 µA) and the consumption stayed with the chip.
Main Processor:
#include <stdio.h>
#include <inttypes.h>
#include "esp_sleep.h"
#include "ulp_riscv.h"
#include "ulp_adc.h"
#include "ulp_main.h"
#include "ulp/example_config.h"
#include "freertos/task.h"
extern const uint8_t ulp_main_bin_start[] asm("_binary_ulp_main_bin_start");
extern const uint8_t ulp_main_bin_end[] asm("_binary_ulp_main_bin_end");
static void init_ulp_program(void);
void app_main(void)
vTaskDelay(pdMS_TO_TICKS(1000));
esp_sleep_wakeup_cause_t cause = esp_sleep_get_wakeup_cause();
/* not a wakeup from ULP, load the firmware */
if ((cause != ESP_SLEEP_WAKEUP_ULP) && (cause != ESP_SLEEP_WAKEUP_TIMER)) {
printf("Not a ULP-RISC-V wakeup (cause = %d), initializing it! \n", cause);
init_ulp_program();
/* RTC peripheral power domain needs to be kept on to keep SAR ADC related configs during sleep */
esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_ON);
ESP_ERROR_CHECK( esp_sleep_enable_ulp_wakeup());
esp_deep_sleep_start();
ulp_adc_cfg_t cfg = {
.adc_n = EXAMPLE_ADC_UNIT,
.channel = EXAMPLE_ADC_CHANNEL,
.width = EXAMPLE_ADC_WIDTH,
.atten = EXAMPLE_ADC_ATTEN,
.ulp_mode = ADC_ULP_MODE_RISCV,
// Commenting out this line will drop the current consumption to ~9 µA
ESP_ERROR_CHECK(ulp_adc_init(&cfg));
esp_err_t err = ulp_riscv_load_binary(ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start));
ESP_ERROR_CHECK(err);
/* The first argument is the period index, which is not used by the ULP-RISC-V timer
* The second argument is the period in microseconds, which gives a wakeup time period of: 2 s
ulp_set_wakeup_period(0, 2000000);
/* Start the program */
err = ulp_riscv_run();
#include <stdint.h>
#include "ulp_riscv_utils.h"
#include "ulp_riscv_adc_ulp_core.h"
int main (void)
SENS.sar_peri_clk_gate_conf.saradc_clk_en = 0;
SENS.sar_power_xpd_sar.force_xpd_sar = 0x2;
return 0;
Main Processor:
#include <stdio.h>
#include <string.h>
#include "soc/rtc_cntl_reg.h"
#include "soc/sens_reg.h"
#include "driver/gpio.h"
#include "driver/rtc_io.h"
#include "ulp.h"
#include "esp_adc/adc_oneshot.h"
/* This function is called once after power-on reset, to load ULP program into
* RTC memory and configure the ADC.
/* This function is called every time before going into deep sleep.
* It starts the ULP program and resets measurement counter.
static void start_ulp_program(void);
void app_main(void)
/* If user is using USB-serial-jtag then idf monitor needs some time to
* re-connect to the USB port. We wait 1 sec here to allow for it to make the reconnection
* before we print anything. Otherwise the chip will go back to sleep again before the user
* has time to monitor any output.
if (cause != ESP_SLEEP_WAKEUP_ULP) {
printf("Not ULP wakeup\n");
init_ulp_program();
printf("Entering deep sleep\n\n");
start_ulp_program();
ESP_ERROR_CHECK( esp_sleep_enable_ulp_wakeup() );
#if !CONFIG_IDF_TARGET_ESP32
#endif
esp_err_t err = ulp_load_binary(0, ulp_main_bin_start,
(ulp_main_bin_end - ulp_main_bin_start) / sizeof(uint32_t));
.ulp_mode = ADC_ULP_MODE_FSM,
/* Set ULP wake up period to 2 s */
#if CONFIG_IDF_TARGET_ESP32
/* Disconnect GPIO12 and GPIO15 to remove current drain through
* pullup/pulldown resistors on modules which have these (e.g. ESP32-WROVER)
* GPIO12 may be pulled high to select flash voltage.
rtc_gpio_isolate(GPIO_NUM_12);
rtc_gpio_isolate(GPIO_NUM_15);
#endif // CONFIG_IDF_TARGET_ESP32
esp_deep_sleep_disable_rom_logging(); // suppress boot messages
esp_err_t err = ulp_run(&ulp_entry - RTC_SLOW_MEM);
ULP:
#include "soc/soc_ulp.h"
#include "soc/rtc_io_reg.h"
/* Code goes into .text section */
.text
.global entry
entry:
// Disable the SAR ADC
WRITE_RTC_REG(SENS_SAR_PERI_CLK_GATE_CONF_REG, SENS_SARADC_CLK_EN_S, 1, 0)
WRITE_RTC_REG(SENS_SAR_PERI_CLK_GATE_CONF_REG, SENS_IOMUX_CLK_EN_S, 1, 0)
WRITE_RTC_REG(SENS_SAR_POWER_XPD_SAR_REG, SENS_SARCLK_EN_S, 1, 0)
WRITE_RTC_REG(SENS_SAR_POWER_XPD_SAR_REG, SENS_FORCE_XPD_SAR_S, 2, 2)
WAIT 100000
jump wake_up
exit:
halt
.global wake_up
wake_up:
/* Check if the system can be woken up */
READ_RTC_FIELD(RTC_CNTL_LOW_POWER_ST_REG, RTC_CNTL_RDY_FOR_WAKEUP)
and r0, r0, 1
jump exit, eq
/* Wake up the SoC, end program */
wake
WRITE_RTC_FIELD(RTC_CNTL_STATE0_REG, RTC_CNTL_ULP_CP_SLP_TIMER_EN, 0)
halt
It stands to reason that if you undo all changes made as a result of the ADC initialisation then the sleep current will be as if it had never been initialised at all.
The registers you're altering look about right at first glance, but I'm not sure this code is helping with troubleshooting. There are all kinds of race conditions going on in there, and the two are doing different things.
If you still aren't seeing ~10uA then post your updated code and ESP-IDF version, and I'll have a look.
Thank you, I appreciate any feedback. I'm not sure I quite understand. Could you be more specific about what you mean, what race conditions you see and what I should change in the example code? Should we maybe move forward with just one of the ULPs? FSM always had lower currents than RISCV, so I think that's the way to go.
I tried to follow the approach of undoing everything that the ulp_adc_init() does. I went through the code and found that all registers that are modified are in rtc_io_reg.h, rtc_cntl_reg.h and sens_reg.h. I then modified my code to just read all registers in these files before and after ulp_adc_init(). For those where I saw changes made, I tried to undo the changes right after calling ulp_adc_init().
This works for some registers, but SENS_SAR_COCPU_INT_RAW_REG, RTC_GPIO_IN_REG and RTC_CNTL_INT_RAW_REG seem to be protected (maybe for good reason?) and I can't modify them back to their original values.
I don't see any change in the 50 µA current consuption by undoing the changes to those registers where it is possible.
Main processor:
ULP-FSM:
I have attached a table of a comparison of all the registers from executing the above code. Remaining differences are marked in yellow.
I went back to using Eclipse with ESP-IDF 5.1.1.
I appreciate any help with this.
Main processor:
#include <stdio.h>
#include <string.h>
#include "ulp.h"
#include "esp_log.h"
#include "soc/rtc_periph.h"
#include "soc/soc.h"
#include "esp32s3/rom/ets_sys.h"
#define READ_AND_PRINT(REG) \
reg_value = REG_READ(REG); \
printf(#REG ": 0x%08" PRIX32 "\n", reg_value);
void app_main(void)
init_ulp_program();
#endif
.adc_n = 0,
.channel = 6,
.width = 0,
.atten = 3,
// periph_module_enable(PERIPH_RMT_MODULE);
// uint32_t regState = *((volatile uint32_t *) (RTC_IO_TOUCH_PAD2_REG));
// ESP_LOGI("MAIN", "ULP: PAD 2 before %lu ", regState);
vTaskDelay(200 / portTICK_PERIOD_MS);
uint32_t reg_value;
READ_AND_PRINT(SENS_SAR_READER1_CTRL_REG)
READ_AND_PRINT(SENS_SAR_READER1_STATUS_REG)
READ_AND_PRINT(SENS_SAR_MEAS1_CTRL1_REG)
READ_AND_PRINT(SENS_SAR_MEAS1_CTRL2_REG)
READ_AND_PRINT(SENS_SAR_MEAS1_MUX_REG)
READ_AND_PRINT(SENS_SAR_ATTEN1_REG)
READ_AND_PRINT(SENS_SAR_AMP_CTRL1_REG)
READ_AND_PRINT(SENS_SAR_AMP_CTRL2_REG)
READ_AND_PRINT(SENS_SAR_AMP_CTRL3_REG)
READ_AND_PRINT(SENS_SAR_READER2_CTRL_REG)
READ_AND_PRINT(SENS_SAR_READER2_STATUS_REG)
READ_AND_PRINT(SENS_SAR_MEAS2_CTRL1_REG)
READ_AND_PRINT(SENS_SAR_MEAS2_CTRL2_REG)
READ_AND_PRINT(SENS_SAR_MEAS2_MUX_REG)
READ_AND_PRINT(SENS_SAR_ATTEN2_REG)
READ_AND_PRINT(SENS_SAR_POWER_XPD_SAR_REG)
READ_AND_PRINT(SENS_SAR_SLAVE_ADDR1_REG)
READ_AND_PRINT(SENS_SAR_SLAVE_ADDR2_REG)
READ_AND_PRINT(SENS_SAR_SLAVE_ADDR3_REG)
READ_AND_PRINT(SENS_SAR_SLAVE_ADDR4_REG)
READ_AND_PRINT(SENS_SAR_TSENS_CTRL_REG)
READ_AND_PRINT(SENS_SAR_TSENS_CTRL2_REG)
READ_AND_PRINT(SENS_SAR_I2C_CTRL_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_CONF_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_DENOISE_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES1_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES2_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES3_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES4_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES5_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES6_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES7_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES8_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES9_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES10_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES11_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES12_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES13_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_THRES14_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_CHN_ST_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS0_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS1_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS2_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS3_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS4_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS5_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS6_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS7_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS8_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS9_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS10_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS11_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS12_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS13_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_STATUS14_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_SLP_STATUS_REG)
READ_AND_PRINT(SENS_SAR_TOUCH_APPR_STATUS_REG)
READ_AND_PRINT(SENS_SAR_COCPU_STATE_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_RAW_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_ENA_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_ST_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_CLR_REG)
READ_AND_PRINT(SENS_SAR_COCPU_DEBUG_REG)
READ_AND_PRINT(SENS_SAR_HALL_CTRL_REG)
READ_AND_PRINT(SENS_SAR_NOUSE_REG)
READ_AND_PRINT(SENS_SAR_PERI_CLK_GATE_CONF_REG)
READ_AND_PRINT(SENS_SAR_PERI_RESET_CONF_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_ENA_W1TS_REG)
READ_AND_PRINT(SENS_SAR_COCPU_INT_ENA_W1TC_REG)
READ_AND_PRINT(SENS_SAR_DEBUG_CONF_REG)
READ_AND_PRINT(SENS_SARDATE_REG)
READ_AND_PRINT(RTC_GPIO_OUT_REG)
READ_AND_PRINT(RTC_GPIO_OUT_W1TS_REG)
READ_AND_PRINT(RTC_GPIO_OUT_W1TC_REG)
READ_AND_PRINT(RTC_GPIO_ENABLE_REG)
READ_AND_PRINT(RTC_GPIO_ENABLE_W1TS_REG)
READ_AND_PRINT(RTC_GPIO_ENABLE_W1TC_REG)
READ_AND_PRINT(RTC_GPIO_STATUS_REG)
READ_AND_PRINT(RTC_GPIO_STATUS_W1TS_REG)
READ_AND_PRINT(RTC_GPIO_STATUS_W1TC_REG)
READ_AND_PRINT(RTC_GPIO_IN_REG)
READ_AND_PRINT(RTC_GPIO_PIN0_REG)
READ_AND_PRINT(RTC_GPIO_PIN1_REG)
READ_AND_PRINT(RTC_GPIO_PIN2_REG)
READ_AND_PRINT(RTC_GPIO_PIN3_REG)
READ_AND_PRINT(RTC_GPIO_PIN4_REG)
READ_AND_PRINT(RTC_GPIO_PIN5_REG)
READ_AND_PRINT(RTC_GPIO_PIN6_REG)
READ_AND_PRINT(RTC_GPIO_PIN7_REG)
READ_AND_PRINT(RTC_GPIO_PIN8_REG)
READ_AND_PRINT(RTC_GPIO_PIN9_REG)
READ_AND_PRINT(RTC_GPIO_PIN10_REG)
READ_AND_PRINT(RTC_GPIO_PIN11_REG)
READ_AND_PRINT(RTC_GPIO_PIN12_REG)
READ_AND_PRINT(RTC_GPIO_PIN13_REG)
READ_AND_PRINT(RTC_GPIO_PIN14_REG)
READ_AND_PRINT(RTC_GPIO_PIN15_REG)
READ_AND_PRINT(RTC_GPIO_PIN16_REG)
READ_AND_PRINT(RTC_GPIO_PIN17_REG)
READ_AND_PRINT(RTC_GPIO_PIN18_REG)
READ_AND_PRINT(RTC_GPIO_PIN19_REG)
READ_AND_PRINT(RTC_GPIO_PIN20_REG)
READ_AND_PRINT(RTC_GPIO_PIN21_REG)
READ_AND_PRINT(RTC_IO_RTC_DEBUG_SEL_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD0_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD1_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD2_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD3_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD4_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD5_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD6_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD7_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD8_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD9_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD10_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD11_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD12_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD13_REG)
READ_AND_PRINT(RTC_IO_TOUCH_PAD14_REG)
READ_AND_PRINT(RTC_IO_XTAL_32P_PAD_REG)
READ_AND_PRINT(RTC_IO_XTAL_32N_PAD_REG)
READ_AND_PRINT(RTC_IO_PAD_DAC1_REG)
READ_AND_PRINT(RTC_IO_PAD_DAC2_REG)
READ_AND_PRINT(RTC_IO_RTC_PAD19_REG)
READ_AND_PRINT(RTC_IO_RTC_PAD20_REG)
READ_AND_PRINT(RTC_IO_RTC_PAD21_REG)
READ_AND_PRINT(RTC_IO_EXT_WAKEUP0_REG)
READ_AND_PRINT(RTC_IO_XTL_EXT_CTR_REG)
READ_AND_PRINT(RTC_IO_SAR_I2C_IO_REG)
READ_AND_PRINT(RTC_IO_TOUCH_CTRL_REG)
READ_AND_PRINT(RTC_IO_DATE_REG)
READ_AND_PRINT(RTC_CNTL_TIME0_REG)
READ_AND_PRINT(RTC_CNTL_TIME1_REG)
READ_AND_PRINT(RTC_CNTL_OPTIONS0_REG)
READ_AND_PRINT(RTC_CNTL_SLP_TIMER0_REG)
READ_AND_PRINT(RTC_CNTL_SLP_TIMER1_REG)
READ_AND_PRINT(RTC_CNTL_TIME_UPDATE_REG)
READ_AND_PRINT(RTC_CNTL_TIME_LOW0_REG)
READ_AND_PRINT(RTC_CNTL_TIME_HIGH0_REG)
READ_AND_PRINT(RTC_CNTL_STATE0_REG)
READ_AND_PRINT(RTC_CNTL_TIMER1_REG)
READ_AND_PRINT(RTC_CNTL_TIMER2_REG)
READ_AND_PRINT(RTC_CNTL_TIMER3_REG)
READ_AND_PRINT(RTC_CNTL_TIMER4_REG)
READ_AND_PRINT(RTC_CNTL_TIMER5_REG)
READ_AND_PRINT(RTC_CNTL_TIMER6_REG)
READ_AND_PRINT(RTC_CNTL_ANA_CONF_REG)
READ_AND_PRINT(RTC_CNTL_RESET_STATE_REG)
READ_AND_PRINT(RTC_CNTL_WAKEUP_STATE_REG)
READ_AND_PRINT(RTC_CNTL_INT_ENA_REG)
READ_AND_PRINT(RTC_CNTL_INT_RAW_REG)
READ_AND_PRINT(RTC_CNTL_INT_ST_REG)
READ_AND_PRINT(RTC_CNTL_INT_CLR_REG)
READ_AND_PRINT(RTC_CNTL_STORE0_REG)
READ_AND_PRINT(RTC_CNTL_STORE1_REG)
READ_AND_PRINT(RTC_CNTL_STORE2_REG)
READ_AND_PRINT(RTC_CNTL_STORE3_REG)
READ_AND_PRINT(RTC_CNTL_EXT_XTL_CONF_REG)
READ_AND_PRINT(RTC_CNTL_EXT_WAKEUP_CONF_REG)
READ_AND_PRINT(RTC_CNTL_SLP_REJECT_CONF_REG)
READ_AND_PRINT(RTC_CNTL_CPU_PERIOD_CONF_REG)
READ_AND_PRINT(RTC_CNTL_SDIO_ACT_CONF_REG)
READ_AND_PRINT(RTC_CNTL_CLK_CONF_REG)
READ_AND_PRINT(RTC_CNTL_SLOW_CLK_CONF_REG)
READ_AND_PRINT(RTC_CNTL_SDIO_CONF_REG)
READ_AND_PRINT(RTC_CNTL_BIAS_CONF_REG)
READ_AND_PRINT(RTC_CNTL_REG)
READ_AND_PRINT(RTC_CNTL_PWC_REG)
READ_AND_PRINT(RTC_CNTL_REGULATOR_DRV_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_DIG_PWC_REG)
READ_AND_PRINT(RTC_CNTL_DIG_ISO_REG)
READ_AND_PRINT(RTC_CNTL_WDTCONFIG0_REG)
READ_AND_PRINT(RTC_CNTL_WDTCONFIG1_REG)
READ_AND_PRINT(RTC_CNTL_WDTCONFIG2_REG)
READ_AND_PRINT(RTC_CNTL_WDTCONFIG3_REG)
READ_AND_PRINT(RTC_CNTL_WDTCONFIG4_REG)
READ_AND_PRINT(RTC_CNTL_WDTFEED_REG)
READ_AND_PRINT(RTC_CNTL_WDTWPROTECT_REG)
READ_AND_PRINT(RTC_CNTL_SWD_CONF_REG)
READ_AND_PRINT(RTC_CNTL_SWD_WPROTECT_REG)
READ_AND_PRINT(RTC_CNTL_SW_CPU_STALL_REG)
READ_AND_PRINT(RTC_CNTL_STORE4_REG)
READ_AND_PRINT(RTC_CNTL_STORE5_REG)
READ_AND_PRINT(RTC_CNTL_STORE6_REG)
READ_AND_PRINT(RTC_CNTL_STORE7_REG)
READ_AND_PRINT(RTC_CNTL_LOW_POWER_ST_REG)
READ_AND_PRINT(RTC_CNTL_DIAG0_REG)
READ_AND_PRINT(RTC_CNTL_PAD_HOLD_REG)
READ_AND_PRINT(RTC_CNTL_DIG_PAD_HOLD_REG)
READ_AND_PRINT(RTC_CNTL_EXT_WAKEUP1_REG)
READ_AND_PRINT(RTC_CNTL_EXT_WAKEUP1_STATUS_REG)
READ_AND_PRINT(RTC_CNTL_BROWN_OUT_REG)
READ_AND_PRINT(RTC_CNTL_TIME_LOW1_REG)
READ_AND_PRINT(RTC_CNTL_TIME_HIGH1_REG)
READ_AND_PRINT(RTC_CNTL_XTAL32K_CLK_FACTOR_REG)
READ_AND_PRINT(RTC_CNTL_XTAL32K_CONF_REG)
READ_AND_PRINT(RTC_CNTL_ULP_CP_TIMER_REG)
READ_AND_PRINT(RTC_CNTL_ULP_CP_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_COCPU_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_CTRL1_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_CTRL2_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_SCAN_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_SLP_THRES_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_APPROACH_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_FILTER_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_USB_CONF_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_TIMEOUT_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_SLP_REJECT_CAUSE_REG)
READ_AND_PRINT(RTC_CNTL_OPTION1_REG)
READ_AND_PRINT(RTC_CNTL_SLP_WAKEUP_CAUSE_REG)
READ_AND_PRINT(RTC_CNTL_ULP_CP_TIMER_1_REG)
READ_AND_PRINT(RTC_CNTL_INT_ENA_W1TS_REG)
READ_AND_PRINT(RTC_CNTL_INT_ENA_W1TC_REG)
READ_AND_PRINT(RTC_CNTL_RETENTION_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_PG_CTRL_REG)
READ_AND_PRINT(RTC_CNTL_FIB_SEL_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_DAC_REG)
READ_AND_PRINT(RTC_CNTL_TOUCH_DAC1_REG)
READ_AND_PRINT(RTC_CNTL_COCPU_DISABLE_REG)
READ_AND_PRINT(RTC_CNTL_DATE_REG)
uint32_t reg_value_bef = REG_READ(SENS_SAR_MEAS1_CTRL2_REG);
uint32_t reg_value_bef2 = REG_READ(SENS_SAR_PERI_CLK_GATE_CONF_REG);
uint32_t reg_value_bef3 = REG_READ(RTC_IO_TOUCH_PAD7_REG);
uint32_t reg_value_bef4 = REG_READ(SENS_SAR_READER1_CTRL_REG);
uint32_t reg_value_bef5 = REG_READ(RTC_CNTL_INT_RAW_REG);
uint32_t reg_value_bef6 = REG_READ(SENS_SAR_COCPU_INT_RAW_REG);
uint32_t reg_value_bef7 = REG_READ(RTC_GPIO_IN_REG);
REG_WRITE(SENS_SAR_MEAS1_CTRL2_REG, reg_value_bef);
REG_WRITE(SENS_SAR_PERI_CLK_GATE_CONF_REG, reg_value_bef2);
REG_WRITE(RTC_IO_TOUCH_PAD7_REG, reg_value_bef3);
REG_WRITE(SENS_SAR_READER1_CTRL_REG, reg_value_bef4);
REG_WRITE(RTC_CNTL_INT_RAW_REG, reg_value_bef5);
REG_WRITE(SENS_SAR_COCPU_INT_RAW_REG, reg_value_bef6);
REG_WRITE(RTC_GPIO_IN_REG, reg_value_bef7);
// regState = READ_PERI_REG(RTC_IO_TOUCH_PAD2_REG);
// ESP_LOGI("MAIN", "ULP: PAD 2 after %lu ", regState);
ULP-FSM:
.text
.global entry
entry:
WAIT 100000
jump wake_up
exit:
halt
.global wake_up
wake_up:
and r0, r0, 1
jump exit, eq
wake
halt
- ESP32-S3_ADC_RegCmp.pdf
- (75.07 KiB) Downloaded 34164 times
Hi hcasper,
I had a chance to look at this today. This line here is the culprit (via init_ulp_program->ulp_adc_init->adc_oneshot_new_unit)
https://github.com/espressif/esp-idf/bl ... #L126-L130
which in turn sets
https://github.com/espressif/esp-idf/bl ... .c#L82-L95
which are used to configure these RTC registers:
https://github.com/espressif/esp-idf/bl ... eep.c#L216
https://github.com/espressif/esp-idf/bl ... eep.c#L239
Setting these back to their low power values fixes your problem. You can confirm this by adding these two lines immediately before esp_deep_sleep_start in your above code:
esp_sleep_enable_adc_tsens_monitor(true);which in turn sets
rtc_regulator_fpu = 1, dbg_atten_slp = RTC_CNTL_DBG_ATTEN_DEEPSLEEP_NODROPwhich are used to configure these RTC registers:
REG_SET_FIELD(RTC_CNTL_BIAS_CONF_REG, RTC_CNTL_DBG_ATTEN_DEEP_SLP, cfg.dbg_atten_slp);
REG_SET_FIELD(RTC_CNTL_REG, RTC_CNTL_REGULATOR_FORCE_PU, cfg.rtc_regulator_fpu);https://github.com/espressif/esp-idf/bl ... eep.c#L239
void esp_sleep_enable_adc_tsens_monitor(bool enable);
esp_sleep_enable_adc_tsens_monitor(false);Re: ESP32-S3 ULP power consumption
Thank you so much boarchuz, that is the first step forward so far. I can reproduce the result, that adding
before esp_deep_sleep_start() does drop the current from about 50 µA to about 9 µA, which is great news.
That, however, is not the final solution for my application. Like I was expecting, the esp_sleep_enable_adc_tsens_monitor(true) is there for a reason. Without it, when I do
on the ULP-FSM, the current rises to about 200 µA and it never wakes up. It seems like that makes it crash.
I have then tried to set the two registers that are modified by esp_sleep_enable_adc_tsens_monitor(true) from the ULP with
to avoid this, but no luck.
Just as an alternative check, I didn't call esp_sleep_enable_adc_tsens_monitor(false) and tried to get to the 9 µA by
on the ULP, without trying to read the ADC. The current stayed at 50 µA.
I'm starting to think that there might just be a problem with writing to these registers from ULP?
adc r2, 0, 7I have then tried to set the two registers that are modified by esp_sleep_enable_adc_tsens_monitor(true) from the ULP with
WRITE_RTC_FIELD(RTC_CNTL_REG, RTC_CNTL_REGULATOR_FORCE_PU, 1)
WRITE_RTC_FIELD(RTC_CNTL_BIAS_CONF_REG, RTC_CNTL_DBG_ATTEN_DEEP_SLP, 0)
WAIT 1000
adc r2, 0, 7
WRITE_RTC_FIELD(RTC_CNTL_REG, RTC_CNTL_REGULATOR_FORCE_PU, 0)
WRITE_RTC_FIELD(RTC_CNTL_BIAS_CONF_REG, RTC_CNTL_DBG_ATTEN_DEEP_SLP, <I tried 0, 14, 15>)
Try setting SENS_FORCE_XPD_SAR to FORCE_PU (can't recall the value) before the ULP ADC instruction.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
