ESP32-S3 RGB LCD maximum throughput
Re: ESP32-S3 RGB LCD maximum throughput
Hi everyone at this topic,
In the past two months I have been trying to fine tune the parameters in the RGB LCD example in the esp-idf repo (https://github.com/espressif/esp-idf/tr ... /rgb_panel) to suit my panel, but I can not seem to find parameters that makes the display stop flickering. I can find parameters that makes it stand still and not scroll/shift, but then it will show a visible flicker.
I have tried to read the datasheet for the LCD, could anyone here tell me what parameters I should use according to the attached image?
When I use the following parameters, the screen does not shift (although they don't look anything like the datasheet):
and pixel clock:
Would love some input on what values to try according to the datasheet, and also how to get rid of the flickering issue.
// The following parameters should refer to LCD spec
.hsync_back_porch = 800,
.hsync_front_porch = 200,
.hsync_pulse_width = 48,
.vsync_back_porch = 31,
.vsync_front_porch = 13,
.vsync_pulse_width = 1,
.flags.pclk_active_neg = true,
#define EXAMPLE_LCD_PIXEL_CLOCK_HZ (12 * 1000 * 1000)
- Screenshot_20230206_013210.png (59.56 KiB) Viewed 5336 times
Just a FYI, thanks for the help on the bounce buffers. I'm able to get a stable 30FPS at RGB332 on a 1024x600 RGB dot clock display. It's all to service a little computer running on just a ESP32-S3 running Micropython, with support for "hardware" sprites and scrolling. All the code and hardware specs are here:
https://github.com/bwhitman/tulipcc
MasterExploder
Did you find any solution to this? i am experiecing the same issue with different LCD screen.
With 12 Mhz it works perfectly, but when i try to go with more than 14.6, i see the same problems you had on your screen.
MasterExploder
Did you manage to solve this? I have the same problem with my project, if so, how did you do It?
Baremetal91
QIO among others iirc will be overwritten by menuconfig to lesser values if you dont un-select "auto-detect flash type". It's explained in the "i" button. Search "flash" in menuconfig for relevant settings.
