is there any issue using io0/io4 for i2c?
Posted: Tue Apr 09, 2019 5:24 am
by stoikos
I am trying to use IO0 for SDA and IO4 for SCL in I2C. I have tried with 4.7k external pullups in both pins and no pullups as well. I2cscanners fail to connect to sensors. When I am using other pins everything works fine. Any ideas?
Re: is there any issue using io0/io4 for i2c?
Posted: Tue Apr 09, 2019 12:08 pm
by username
IO0 is a special pin that already has a pullup on it. Its used to program the part. I suggest looking at the data sheet first so you can understand what pins to use and not to.
Posted: Tue Apr 09, 2019 2:18 pm
by stoikos
I know how they function, nevertheless in the esp32 docs they say that after boot they behave like normal pins. I do use them for the boot process but it doesnt seem to be working, while the same software when its using other pins is working
Posted: Tue Apr 09, 2019 2:25 pm
by username
Not sure, Personally I steer clear of using GPIO0. Throw a scope on the SCL/SDA lines and have a look.
Posted: Tue Apr 09, 2019 3:11 pm
by fly135
Pretty sure that GPIO 0 is available after boot. If you are going work on stuff like this it's worth getting a cheap scope to analyze these kinds of problems.
John A
Posted: Wed Apr 10, 2019 3:24 am
by stoikos
there are not enough pins on esp32. I am already using port expanders, multiple multiplexers on that pcb. I need to make them work
I will look with my trusted rigol. I was trying to determine if there is something internal that prohibits them to be used as i2c. they have internal pullups, they are IO (unlike >io34). so after boot they should work. right? the same software on different pins works like a charm
Posted: Mon May 06, 2019 6:14 pm
by stoikos
This is the code that I am running. I put a scope on IO0 and I get the attached signal. the same program on another pin works like a charm.
void task_i2cscanner(void *ignore)
ESP_LOGD("Sensor", ">> i2cScanner");
i2c_config_t conf;
conf.mode = I2C_MODE_MASTER;
conf.sda_io_num = SCL_PIN;
conf.scl_io_num = SDA_PIN;
conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
conf.master.clk_speed = 400000;
i2c_param_config(I2C_NUM_0, &conf);
i2c_driver_install(I2C_NUM_0, I2C_MODE_MASTER, 0, 0, 0);
while (true)
vTaskDelay(1);
int i;
esp_err_t espRc;
printf(" SDA_PIN %i SCL_PIN %i\n", conf.sda_io_num, conf.scl_io_num);
printf(" 0 1 2 3 4 5 6 7 8 9 a b c d e f\n");
printf("00: ");
for (i = 3; i < 0x78; i++) {
i2c_cmd_handle_t cmd = i2c_cmd_link_create();
i2c_master_start(cmd);
i2c_master_write_byte(cmd, (i << 1) | I2C_MASTER_WRITE, 1 /* expect ack */);
i2c_master_stop(cmd);
espRc = i2c_master_cmd_begin(I2C_NUM_0, cmd, 1000 / portTICK_PERIOD_MS);
if (i % 16 == 0) {
printf("\n%.2x:", i);
if (espRc == 0) {
printf(" %.2x", i);
else {
printf(" --");
//ESP_LOGD(tag, "i=%d, rc=%d (0x%x)", i, espRc, espRc);
i2c_cmd_link_delete(cmd);
printf("\n");
//vTaskDelete(NULL);
}[Codebox=cpp file=Untitled.cpp][/Codebox]
Posted: Tue May 07, 2019 3:56 pm
by username
You never want to use internal pullups for I2C on ANY device. They will all be too weak to do the job properly.
