what would cause repeated RTC watch dog reset? (RTCWDT_RTC_RESET)
RMandR
Postby RMandR » Tue Apr 09, 2019 10:51 pm
I programmed a custom board with ESP32-WROOM-32 module on it. ESP_PROG connects and flashes without issues but the Monitor output is the repeated "error" below.
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x40080764,len:33006
ets Jun 8 2016 00:22:57
What have I not done right?
WiFive
Re: what would cause repeated RTC watch dog reset? (RTCWDT_RTC_RESET)
Postby WiFive » Wed Apr 10, 2019 3:41 am
What bin files did you flash and with which software?
RMandR
Postby RMandR » Wed Apr 10, 2019 1:06 pm
I compiled the Hello World sample using "make flash monitor".
It did however, go through a bunch of config questions to which I picked all default values.
Kashyapkoshti
Postby Kashyapkoshti » Thu Nov 19, 2020 9:52 am
rst:0x10 (RTCWDT_RTC_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
I am getting this error in my esp32 devkit v1
How to solve it?
I am using arduino IDE for programming the esp32.
alanesq
Postby alanesq » Thu Nov 19, 2020 11:04 am
I seem to remember having an esp32 a good while back which was giving an error something like this, I discovered that if I changed "flash frequency" to 40mhz and it then worked - worth a try.
Any kind of problem like this I find the first thing to check is the power supply as if it has a problem with this you will get all kinds of weird errors/restarts etc..
This is advice I have not taken myself several times and as a resulted wasted hours on a wild goose chase - lol
Kashyapkoshti
Postby Kashyapkoshti » Thu Dec 03, 2020 1:47 pm
I have tried 40Mhz with 115200 baud rate but no luck!
Users browsing this forum: Qwantbot and 3 guests
