I am designing a small robot with ESP32 at it's core. It will have two modes of operation - automatic (navigating with an ultrasound and other sensors), and a manual mode (controlled remotely via Wi-Fi). For manual control, I want to have a video camera feed from the robot over Wi-Fi. I've seen several similar projects using OV7670, a cheap camera that is well documented for usage with ESP32. Problem is, this camera requires a ton of pins, and since my robot has a lot of other sensors and modules to control, I don't have that many. I want to do this without port expanders, as these introduce other complexities that I want to avoid.
So, what I'm looking for is a camera module that would work with fewer pins. As I understand it, I2C protocol is too slow for anything but a few frames per second at a very low resolution. Maybe there are some SPI cameras out there? I found some made by ArduCam, but these are very expensive and very bulky. I'm looking for something small (4x4cm at most), cheap (under $15) and that would work using no more than 6 pins on ESP32. I don't need great image quality or 24 frames per second - just enough to make real-time control of the robot possible (maybe 10 fps).
Can you name some options, please?
Video camera recommendation for a ESP32 based robot
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: trendictionbot and 1 guest
- All times are UTC
- Top
- Delete cookies
About Us
Information
