We are awash in excellent MQTT clients for ESP32 (as it should be). Here is yet another for the mix. The Eclipse Paho project provides an embedded-C client component that can be found here:
https://github.com/eclipse/paho.mqtt.embedded-c
I downloaded this and with minor tweaks got it working on ESP32 with no significant issues. I tested against a Linux hosted MQTT Mosquitto broker and it seems to be working just fine. Here is a link to the port to ESP32 with a sample ...
https://github.com/nkolban/esp32-snippe ... embedded_c
Again, let me stress that the changes from the original Github project were minor.
[Info] MQTT Eclipse Paho client component
Re: [Info] MQTT Eclipse Paho client component
I got azure umqtt working, I used the arduino version for the esp8266 as an example.
Reworked the wificlientsecure to use openssl and got it working. Cannot share though ='( Great work!
esp-idf : https://github.com/espressif/esp-dif.git
i have a question in a upload code (https://github.com/nkolban/esp32-snippets.git)
1. A save paho_mqtt_embedded_c folder in esp-idf/component
2. Build the files in the esp32_sample folder
3. MQTTClient-C/src/linux/MQTTLinux.h file error generated
4. change the component.mk file (MQTTClient-C/src/linux -> MQTTClient-C/src/FreeRTOS)
5. FreeRTOS_Sockets.h FreeRTOS_IP.h ... many files (no such file or directory)error generated
How did you solve it?
Its been 5 months since I looked ... but if I remember ... we take the whole folder found here:
And place that in our ESP32 project's components directory.
This would end up with:
<YourProject>/components/paho_mqtt_embedded_c
Since "paho_mqtt_embedded_c" contains an ESP-IDF "component.mk" file, it should "just build" when you run make in your project's home directory. No other modifications are needed. The result will be that the MQTT client API is now available to your apps.
Hey, I just tried it out and it couldn't finish building. Can you give me a quick hand?
It was placed to match the ESP32 documentation
The make debug- myProject/
- Makefile
- sdkconfig
- components/ - component1/ - component.mk
- Kconfig
- src1.c
- component2/ - component.mk
- Kconfig
- src1.c
- include/ - component2.h
- main/ - src1.c
- src2.c
- component.mk
- build/
The errormake: Circular /home/esp32/Projects/ESP32/mqtt_paho/mqtt_paho_port/build/MQTT_Test <- /home/esp32/Projects/ESP32/mqtt_paho/mqtt_paho_port/build/MQTT_Test dependency dropped.
Considering target file '.elf'.
File '.elf' does not exist.
Putting child 0xe10190 (.elf) PID 25077 on the chain.
Live child 0xe10190 (.elf) PID 25077
LD .elf
Reaping winning child 0xe10190 PID 25077
Live child 0xe10190 (.elf) PID 25078
xtensa-esp32-elf-gcc: error: .map: No such file or directory
Reaping losing child 0xe10190 PID 25078
/home/esp32/esp/esp-idf/make/project.mk:373: recipe for target '.elf' failed
make: *** [.elf] Error 1
Removing child 0xe10190 PID 25078 from chain.
