fatal error: controller.h: No such file or directory
bombix
Postby bombix » Fri Jan 20, 2017 1:35 pm
Im a complete beginner in the esp32.
I tried the helloworld example with success in the arduino ide and platformio (im using windows).
Im trying the GATT_client examples but i get the error:fatal error: controller.h: No such file or directory
Watt im i doing wrong?
Thanks in advance
bombix
Re: fatal error: controller.h: No such file or directory
Postby bombix » Mon Jan 23, 2017 11:35 am
I have been looking and it looks like the problem is with the components.
After i place controller.h in the same folder the ide asks for another file, then another...
How do i include the components folder?
Thanks in advance
irobux
Postby irobux » Tue Feb 21, 2017 9:39 am
You have to check bluetooth in the configuration throuth make menuconfig => "component config". You will tell the SDK to take into account the bt. Then your project will compile with this component and find the files included.
You need not to move the files
Iro
bombix
Postby bombix » Thu Mar 23, 2017 5:45 pm
Im working in windows using platformIO, and im kind of newbie.
I checked the Makefile but theres nothing there.
Thanks in advance
smallwire
Postby smallwire » Fri Apr 05, 2019 11:57 pm
Hi!
I have no idea what this means:
"You have to check bluetooth in the configuration throuth make menuconfig => "component config""
Can you please explain?
Thank you!
Users browsing this forum: meta-externalagent, Qwantbot and 1 guest
