SPI pull down CS
Posted: Fri Apr 26, 2019 2:58 pm
by Ian777
Hey everyone,
I've got my SPI init code defined as the following:
#define GPIO_MOSI 21
#define GPIO_MISO 14
#define GPIO_SCLK 12
#define GPIO_CS 22
    ESP_LOGI(TAG1,"Started master SPI");
    esp_err_t ret;
    spi_device_handle_t handle;
    //Configuration for the SPI bus
    spi_bus_config_t buscfg={
        .mosi_io_num=GPIO_MOSI,
        .miso_io_num=GPIO_MISO,
        .sclk_io_num=GPIO_SCLK,
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
    spi_device_interface_config_t devcfg={
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .clock_speed_hz=5000000,
        .duty_cycle_pos=128,        //50% duty cycle
        .mode=0,
        .spics_io_num=GPIO_CS,
        .cs_ena_posttrans=3,        //Keep the CS low 3 cycles after transaction, to stop slave from missing the last bit when CS has less propagation delay than CLK
        .queue_size=3
Is there anyway to set the CS pin mode as a pull down as I have an external pullup resistor on the line?
Thanks in advance for any help!
Re: SPI pull down CS
Posted: Sun Apr 28, 2019 9:49 am
by Ritesh
Hey everyone,
#define GPIO_CS 22
    esp_err_t ret;
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .mode=0,
        .queue_size=3
I think there is no any way to make it pull down as you have already connected pull up resistor. But still try with making gpio configuration as pull down but I am sure it won't work as you required.
Still, Can you please question into hardware section then might be you will get proper solution for same.
Posted: Mon Apr 29, 2019 10:14 am
by Ian777
Hey everyone,
#define GPIO_CS 22
    esp_err_t ret;
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .mode=0,
        .queue_size=3
Thank you Ritesh, I've cross-posted his to the hardware section. I appreciate the help.
Posted: Tue Apr 30, 2019 1:48 am
by Sprite
I've moved this to the hardware topic and closed the other topics. Please do not cross-post; it risks information being scattered around the forums.
