Log output is UART0 by default. Can not change to UART1?
Or can I turn off the Log output?
Re: Log output is UART0 by default. Can not change to UART1?
If you run "make menuconfig" and then navigate to Component Config -> ESP32 specific you will find an entry called "UART for console output" where you can select UART0 or UART1 ... or none.
Users browsing this forum: Applebot, PerplexityBot, Qwantbot and 1 guest
