Hi all,
When i'm not jtag debugging I get Interrupt wdt timeouts.
I tracked the program counter to "asm("waiti 0");" in freertos_hooks.c:52 called by tasks.c:3293 prvIdleTask.
I thought the register dump would point to the function that was stuck and blocking interrupts. Like the docs describe https://github.com/espressif/esp-idf/bl ... m/wdts.rst
My program isn't inside a loop, it has called vTaskDelay().
I'm not seeing what is not feeding the watchdog timer, any hints on how I can figure out what task is causing the interrupt wdt?
Re: Interrupt wdt timeout
Are you using the very latest master of esp-idf? We had an issue that caused that before, but we fixed it some time ago.
I'm using the VisualGDB esp-idf version.
But it is good to know it is a known issue that has been fixed.
Thanks!
Thanks!
Users browsing this forum: Applebot, Qwantbot and 1 guest
