BLE Watchdog Reset (ASSERT_PARAM(131072 0), in rwble.c at line 235)
mpulis
Postby mpulis » Mon May 06, 2019 9:28 am
Hi all,
I've got an application with an ESP32 using BLE to read data which is continuously being advertised while also advertising itself so that a mobile app can connect to it. This is done by having a dedicated task which switches between advertising and scanning. When the mobile app connects to the module, the module stops advertising and starts scanning continuously while the app is still connected.
The issue is that after an indeterminate amount of time, the module experiences a watchdog timeout, with the following error message displayed:
Guru Meditation Error: Core  0 panic'ed (Interrupt wdt timeout on CPU0)
Core 0 register dump:
PC      : 0x4008a639  PS      : 0x00060f34  A0      : 0x8008e4f0  A1      : 0x3ffbf0d0
0x4008a639: r_assert_param at ??:?
A2      : 0x00000001  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x60008054
A6      : 0x3ffbdccc  A7      : 0x60008050  A8      : 0x8008a639  A9      : 0x3ffbf0b0
A10     : 0x00000004  A11     : 0x00000000  A12     : 0x6000804c  A13     : 0xffffffff
A14     : 0x00000000  A15     : 0xfffffffc  SAR     : 0x00000004  EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000  LBEG    : 0x4008a571  LEND    : 0x4008a578  LCOUNT  : 0x00000000
0x4008a571: r_assert_param at ??:?
0x4008a578: r_assert_param at ??:?
Core 0 was running in ISR context:
EPC1    : 0x4008cf61  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x4008a639
0x4008cf61: r_lld_evt_end_isr at ??:?
ELF file SHA256: be6ad9722a98d30e33a36882ccbd23da5b0c40ef616ae0e315c14c4304ca4188
Backtrace: 0x4008a639:0x3ffbf0d0 0x4008e4ed:0x3ffbf0f0 0x4008f0db:0x3ffbf110 0x4008866d:0x3ffbf130 0x401ab603:0x3ffbab30 0x400d53b3:0x3ffbab50 0x4009898d:0x3ffbab70 0x40099681:0x3ffbab90
0x4008e4ed: r_rwble_isr at ??:?
0x4008f0db: r_rwbtdm_isr_wrapper at intc.c:?
0x4008866d: _xt_lowint1 at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/esp-idf/components/freertos/xtensa_vectors.S:1154
0x401ab603: esp_pm_impl_waiti at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/esp-idf/components/esp32/pm_esp32.c:493
0x400d53b3: esp_vApplicationIdleHook at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/esp-idf/components/esp_common/src/freertos_hooks.c:86
0x4009898d: prvIdleTask at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/esp-idf/components/freertos/tasks.c:3538
0x40099681: vPortTaskWrapper at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/esp-idf/components/freertos/port.c:435
Core 1 register dump:
PC      : 0x4010ec59  PS      : 0x00060a34  A0      : 0x80099684  A1      : 0x3fff2d20
0x4010ec59: bleTimeDivisionTask at C:/Users/mpulis/Desktop/Projects/ESP32/IDF3/msys32/home/ASM16xSEv4/main/ble_interface.c:422
A2      : 0x0003dba8  A3      : 0x00000000  A4      : 0x00060023  A5      : 0x3fff1f70
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x00000000
A10     : 0x00000001  A11     : 0x3ffcd2f4  A12     : 0x3f4125ec  A13     : 0x0000001f
A14     : 0x00000001  A15     : 0x00000005  SAR     : 0x00000004  EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000  LBEG    : 0x40096210  LEND    : 0x4009623e  LCOUNT  : 0xffffffff
0x40096210: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:168
0x4009623e: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:201
Backtrace: 0x4010ec59:0x3fff2d20 0x40099681:0x3fff2d40
WiFi/Bluetooth coexistence performance preference is set to Balance, with the Software controls WiFi/Bluetooth coexistence configuration enabled. The Bluetooth modem sleep option is disabled. The module is not connected to any WiFi station and is also not set up as a WiFi access point, but I should note that the tcpip_adapter_init() function is being called during the initialization procedure for the module.
What could the issue be?
louisthetall
Re: BLE Watchdog Reset (ASSERT_PARAM(131072 0), in rwble.c at line 235)
Postby louisthetall » Mon Dec 30, 2019 5:07 pm
I am seeing a similar error while using BLE:
ASSERT_PARAM(131072 0), in rwbt.c at line 311
PC      : 0x400862c2  PS      : 0x00060034  A0      : 0x8008ab24  A1      : 0x3ffbe690
0x400862c2: r_assert_param at ??:?
A6      : 0x3ffbdce0  A7      : 0x60008050  A8      : 0x800862bd  A9      : 0x3ffbe670
EXCVADDR: 0x00000000  LBEG    : 0x400861f5  LEND    : 0x400861fc  LCOUNT  : 0x00000000
0x400861f5: r_assert_param at ??:?
0x400861fc: r_assert_param at ??:?
EPC1    : 0x4016aa06  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x400862c2
0x4016aa06: bus_uses_iomux_pins at .../esp-idf/components/driver/spi_common.c:378
 (inlined by) spicommon_bus_initialize_io at .../esp-idf/components/driver/spi_common.c:216
ELF file SHA256: 136b13cd0a889b7999307c877c669d74abf1e11125f92e01b8865c3e3c1de725
Backtrace: 0x400862c2:0x3ffbe690 0x4008ab21:0x3ffbe6b0 0x4008af2f:0x3ffbe6d0 0x40084692:0x3ffbe6f0 0x4016aa03:0x3ffbb160 0x400d3ab7:0x3ffbb180 0x4008ff52:0x3ffbb1a0
0x4008ab21: r_rwbt_isr at ??:?
0x4008af2f: r_vhci_isr at ??:?
0x40084692: _xt_lowint1 at .../esp-idf/components/freertos/xtensa_vectors.S:1154
0x4016aa03: bus_uses_iomux_pins at .../esp-idf/components/driver/spi_common.c:378
0x400d3ab7: xPortGetCoreID at .../esp-idf/components/esp32/freertos_hooks.c:86
 (inlined by) esp_vApplicationIdleHook at .../esp-idf/components/esp32/freertos_hooks.c:49
0x4008ff52: vTaskResume at .../esp-idf/components/freertos/tasks.c:4560
I suspect with my application, it might be related to the ble server advertising itself while already being connected to a ble client.
Were you able to find out more about this issue?
