ESP32 WROVER USING U.FL AND PCB ANTENNA
Vaccaro
Postby Vaccaro » Tue May 07, 2019 12:20 pm
I'm developing a solution that needs to use directional bluetooth. I know I can use the modules with u.fl connector with a directional antenna.
My question is, if I use a module that besides the uf.l connector also has the omnidirectional antenna on the pcb. Will the signal be radiated by the two? In case I will have a signal coming out through the directional antenna and another directional signal coming out of the pcb antenna?
This is the module I'm thinking of using.Image
WiFive
Re: ESP32 WROVER USING U.FL AND PCB ANTENNA
Postby WiFive » Tue May 07, 2019 1:21 pm
No only 1 antenna is connected to rf path
Vaccaro
Postby Vaccaro » Tue May 07, 2019 1:31 pm
So, if i use an antenna on the u.fl connector the module will automatically stop using the pcb antenna? Or i have to do something on the hardware and choose this manually?
These resistors have anything to do with this choice?
WiFive
Postby WiFive » Wed May 08, 2019 1:11 am
Yes, exactly. On the ESP32-WROVER-IB (I for IPEX) model that jumper will connect the antenna connector to the rf path and on the ESP32-WROVER-B model it will connect the pcb antenna to the rf path.
GreenieP
Postby GreenieP » Mon May 27, 2024 12:13 am
Sorry to resurrect an old post - but how exactly do you connect an externall antenna to the ESP32-WROVER-B?
Users browsing this forum: No registered users and 6 guests
