ESP32 WROVER USING U.FL AND PCB ANTENNA
Posted: Tue May 07, 2019 12:20 pm
I'm developing a solution that needs to use directional bluetooth. I know I can use the modules with u.fl connector with a directional antenna.
My question is, if I use a module that besides the uf.l connector also has the omnidirectional antenna on the pcb. Will the signal be radiated by the two? In case I will have a signal coming out through the directional antenna and another directional signal coming out of the pcb antenna?
This is the module I'm thinking of using.
