wpa2_enterprise password in esp-idf-v2.0-rc1
current
Postby current » Fri Jan 27, 2017 10:31 pm
We have been setting up the SDK and testing capability of the esp32. Nice device.
When running the wifi example "wpa2_enterprise" it seems that the code as-is does not load the password in the wifi_config setup.
So testing the connection without the password did not get an IP address.
Here is what was changed... we added the password and bssid_set.
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_WIFI_SSID,
            .password = EXAMPLE_EAP_PASSWORD,
            .bssid_set = 0
Was the code supposed to get the password from somewhere else?
Thanks.
WiFive
Re: esp-idf-v2.0-rc1
Postby WiFive » Sat Jan 28, 2017 2:46 am
What is eap_method? Does it matter if it is a valid password or just non null?
You would think
esp_wifi_sta_wpa2_ent_set_password((uint8_t *)EXAMPLE_EAP_PASSWORD, strlen(EXAMPLE_EAP_PASSWORD))
should take care of it.
PS can you edit thread title to be more appropriate
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User and 1 guest
