Override FreeRTOSConfig.h
richard.kang
Postby richard.kang » Sat Jun 01, 2019 2:50 am
I have a project that has a local FreeRTOSConfig.h.
However even when I have COMPONENT_ADD_INCLUDEDIRS in my Makefile, I still encountered error that variable not found, which I have defined in a local FreeRTOSConfig.h
COMPONENT_ADD_INCLUDEDIRS := \
	./includes \
Is there other flag in Makefile that I can use to set priority to include?
Re: Override FreeRTOSConfig.h
Postby Sprite » Sun Jun 02, 2019 1:36 am
Note that esp-idf does not support custom FreeRTOS configs, as it's easy to enable/disable a bunch of features that break the assumptions of the rest of the SDK. With that in mind, which features in particular do you need enabled/disabled?
richard.kang
Postby richard.kang » Sun Jun 02, 2019 8:20 pm
Thanks for your reply.
Sorry I should take a step back and share my use case.
I was looking at using some functions that seems not available in ESP-IDF, e.g. https://www.freertos.org/a00021.html#pcTaskGetName.
Therefore, I am wondering what is the best practices to override the FreeRTOS component of ESP-IDF? Should I have ESP-IDF and FreeRTOS side-by-side in 2 different folders, and so potentially overrides some of the FreeRTOS in ESP-IDF?
Thanks!
Richard
Users browsing this forum: Bytespider, PerplexityBot, PetalBot and 8 guests
