wifi spams serial monitor
nxt518
Postby nxt518 » Mon Jun 03, 2019 12:26 pm
I combined /examples/wifi/getting_started/softAP/ + /examples/protocols/http_server/
Connection and http requests/replies work fine.
But sometimes I get a lot of wifi messages on serial (30 per second):
wifi: ampdu: ignore deleting tx BA0
Module is WROOM32.
How to avoid this messages being generated?
(I dont want to change loglevel, I want to find out the reason.)
nxt518
Re: wifi spams serial monitor
Postby nxt518 » Tue Jun 11, 2019 6:29 am
This also happens with the unmodified /examples/wifi/getting_started/softAP/
A guy over at the Chinese Espressif Forum also has this behaviour.
GAllevto
Postby GAllevto » Tue Jul 23, 2019 8:13 pm
I am having the same problem using Wrover-B (DevKit-C and custom PCB).
The problem only starts occuring after a few minutes, but never at the very beginning after a hard reset.
I am also using the ESP in AP and APSTA mode. I have not tested it using STA only mode.
squonk11
Postby squonk11 » Tue Dec 10, 2019 5:05 pm
I am also having this problem. It seems as if this is related to some problems in my TCP/IP communication. Is there already a fix or workaround for this issue?
"Whoever believes to be someone has stopped becoming someone"
Sokrates
