mqtt:fatal error: mqtt_client.h: No such file or directory
zsjcyzz
Postby zsjcyzz » Mon Jun 10, 2019 6:13 am
hello, i learn the mqtt but find the error in "make flash monitor":
C:/msys32/home/Administrator/esp/esp-idf-release-v3.3/esp-idf-release-v3.3/examples/protocols/mqtt/ssl/main/app_main.c:21:25: fatal error: mqtt_client.h: No such file or directory
compilation terminated.
make[1]: *** [/home/Administrator/esp/esp-idf/make/component_wrapper.mk:286: app_main.o] Error 1
make: *** [C:\msys32\home\Administrator\esp\esp-idf/make/project.mk:467: component-main-build] Error 2
So where i can find the "mqtt_client.h"
Thanks!
fly135
Re: mqtt:fatal error: mqtt_client.h: No such file or directory
Postby fly135 » Mon Jun 10, 2019 3:30 pm
I'm guessing it should be right here..
C:/msys32/home/Administrator/esp/esp-idf/components/mqtt/esp-mqtt/include
But I'm wondering why the IDF path to the project.mk is different than the one it's looking for that file. That is likely the clue to your problem. It may be that you are compiling a IDF v3.3 example with another version of the IDF.
You'll probably find it in....
C:/msys32/home/Administrator/esp/esp-idf-release-v3.3/esp-idf-release-v3.3/components/mqtt/esp-mqtt/include
But that might not be the version of the IDF in your IDF_PATH,
John A
zsjcyzz
Postby zsjcyzz » Wed Jun 12, 2019 1:26 am
Tkanks .
Yep, I cant find the file in that path, But can find in github. .
have a few bugs..
let me see.
