Page 1 of 7
ESP-WROOM-32 AT commands firmware
Posted: Fri Feb 03, 2017 11:11 pm
by wind_energy
hi,
I got the a ESP-WROOM-32 in hope to easy use AT commands to connect our router.
As soon as I got it i`ve checked that I need to put another firmware with AT commands service.
I don`t have now any environment to compile source.
I tryied to download bin file from here: https://github.com/espressif/esp32-at.
Unfortunatelly this link doesn`t work:
You can get AT bin from http://espressif.com/zh-hans/support/do ... d%5B%5D=13
Many thanks for any help.
Best regards,
Pawel
Re: ESP-WROOM-32 AT commands firmware
Posted: Sat Feb 04, 2017 12:21 pm
by Sprite
Moved to General Discussion, this does not belong in News. What is your question exactly?
Posted: Sat Feb 04, 2017 12:59 pm
by WiFive
His question is where is the bin file it doesn't seem to be listed in downloads section on espressif.com
Posted: Sat Feb 04, 2017 1:08 pm
by Sprite
Ah, missed the bit where the link doesn't work. I'll see if I can poke whoever is responsible.
Posted: Sat Feb 04, 2017 1:10 pm
by rudi ;-)
http://esp32.com/viewtopic.php?f=2&t=1058
thanks
Posted: Mon Feb 06, 2017 5:48 am
by Sprite
Fyi: the AT binary isn't available yet because it isn't production-ready. The current AT firmware is compiled with a non-production version of ESP-IDF; apart from that there's also a bug related to AT+RESTORE that we need to fix. We'll edit the git repo to kill the non-working download link for now; expect a binary somewhere after we release ESP-IDF 2.0.
Posted: Mon Feb 06, 2017 9:54 am
by wind_energy
Thank you a lot. Best Regards Pawel
Posted: Mon Feb 06, 2017 9:03 pm
by wind_energy
hi,
The bin file is already done. I`ve gotten it from my supplier of esp modules. Check attachments. Change file name ESP32_ATcommand.bin.rar -> ESP32_ATcommand.bin. enjoy.
Regards,
Pawel
Posted: Tue Feb 07, 2017 1:51 am
by Sprite
Keep in mind that that is a preliminary version of the binary. We may or may not support bugs in this until the official version comes out.
Posted: Wed Feb 08, 2017 9:50 pm
by wind_energy
I`ve downloaded the firmware and there is no response on AT commands.
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0008,len:4
load:0x3ffc000c,len:3812
load:0x40078000,len:4748
load:0x40080000,len:260
entry 0x40080034
[0;32mI (27) boot: Espressif ESP32 2nd stage bootloader v. V0.1[0m
[0;32mI (36) boot: compile time 17:17:25[0m
D (42) esp_image: reading image header @ 0x1000[0m
D (49) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)[0m
D (59) boot: magic e9[0m
D (63) boot: segments 04[0m
D (67) boot: spi_mode 02[0m
D (71) boot: spi_speed 00[0m
D (75) boot: spi_size 01[0m
[0;32mI (79) boot: SPI Speed      : 40MHz[0m
[0;32mI (85) boot: SPI Mode       : DIO[0m
[0;32mI (91) boot: SPI Flash Size : 2MB[0m
[0;32mI (97) boot: Partition Table:[0m
[0;32mI (103) boot: ## Label            Usage          Type ST Offset   Length[0m
D (114) bootloader_flash: mmu set paddr=00000000 count=1[0m
D (122) boot: mapped partition table 0x8000 at 0x3f408000[0m
D (130) boot: load partition table entry 0x3f408000[0m
D (138) boot: type=1 subtype=1[0m
[0;32mI (143) boot:  0 phy_init         RF data          01 01 0000f000 00001000[0m
D (154) boot: load partition table entry 0x3f408020[0m
D (162) boot: type=0 subtype=10[0m
[0;32mI (167) boot:  1 ota_0            OTA app          00 10 00010000 000ea000[0m
D (178) boot: load partition table entry 0x3f408040[0m
D (186) boot: type=1 subtype=2[0m
[0;32mI (190) boot:  2 nvs              WiFi data        01 02 000fa000 00016000[0m
D (202) boot: load partition table entry 0x3f408060[0m
D (209) boot: type=0 subtype=11[0m
[0;32mI (214) boot:  3 ota_1            OTA app          00 11 00110000 000ea000[0m
D (226) boot: load partition table entry 0x3f408080[0m
D (233) boot: type=1 subtype=0[0m
[0;32mI (238) boot:  4 otadata          OTA data         01 00 001fd000 00003000[0m
D (249) boot: load partition table entry 0x3f4080a0[0m
D (257) boot: type=ff subtype=ff[0m
[0;32mI (262) boot: End of partition table[0m
D (269) bootloader_flash: mmu set paddr=001f0000 count=1[0m
[0;32mI (277) boot: Loading app partition at offset 00010000[0m
D (286) esp_image: reading image header @ 0x10000[0m
D (293) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (303) esp_image: reading 9 image segments[0m
D (396) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (396) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00020000)[0m
D (400) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (496) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (538) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (538) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (542) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (563) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (564) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (573) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (585) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (594) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (604) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (647) bootloader_flash: mmu set block paddr=0x00040000 (was 0x00030000)[0m
D (734) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00040000)[0m
D (768) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (768) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (772) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (782) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (793) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (803) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (814) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (824) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (887) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (888) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00060000)[0m
D (891) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (901) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (912) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (922) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (1019) bootloader_flash: mmu set block paddr=0x00070000 (was 0x00060000)[0m
D (1106) bootloader_flash: mmu set block paddr=0x00080000 (was 0x00070000)[0m
D (1192) bootloader_flash: mmu set block paddr=0x00090000 (was 0x00080000)[0m
D (1279) bootloader_flash: mmu set block paddr=0x000a0000 (was 0x00090000)[0m
D (1366) bootloader_flash: mmu set block paddr=0x000b0000 (was 0x000a0000)[0m
D (1453) bootloader_flash: mmu set block paddr=0x000c0000 (was 0x000b0000)[0m
D (1539) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x000c0000)[0m
D (1547) bootloader_flash: mmu set block paddr=0x00010000 (was 0x000d0000)[0m
D (1548) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1554) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1565) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (1575) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (1586) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x00060000)[0m
D (1596) esp_image: reading checksum block at 0xd1620[0m
D (1604) esp_image: reading image header @ 0x10000[0m
D (1611) bootloader_flash: mmu set block paddr=0x00010000 (was 0x000d0000)[0m
D (1622) boot: bin_header: 233 9 2 1 40080a7c[0m
[0;32mI (1629) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512) [0m
D (1641) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1652) boot: found drom segment, map from 00020010 to 3f400010[0m
[0;32mI (1661) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x17978 ( 96632) map[0m
D (1674) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00020000)[0m
D (1684) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1695) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1706) boot: segment 2: paddr=0x00037988 vaddr=0x3ffc2960 size=0x02174 (  8564) load[0m
D (1719) bootloader_flash: mmu set paddr=00030000 count=1[0m
D (1731) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1738) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1748) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1759) boot: segment 3: paddr=0x00039b04 vaddr=0x40080000 size=0x00400 (  1024) load[0m
D (1772) bootloader_flash: mmu set paddr=00030000 count=1[0m
D (1781) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1791) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1801) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1812) boot: segment 4: paddr=0x00039f0c vaddr=0x40080400 size=0x1c420 (115744) load[0m
D (1825) bootloader_flash: mmu set paddr=00030000 count=3[0m
D (1888) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1889) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1892) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1903) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
[0;32mI (1913) boot: segment 5: paddr=0x00056334 vaddr=0x400c0000 size=0x00034 (    52) load[0m
D (1926) bootloader_flash: mmu set paddr=00050000 count=1[0m
D (1935) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1945) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1956) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1967) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
[0;32mI (1977) boot: segment 6: paddr=0x00056370 vaddr=0x00000000 size=0x09c98 ( 40088) [0m
D (1990) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (2000) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (2011) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (2021) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (2032) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (2042) boot: found irom segment, map from 00060018 to 400d0018[0m
[0;32mI (2052) boot: segment 7: paddr=0x00060010 vaddr=0x400d0018 size=0x715f8 (464376) map[0m
D (2065) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00060000)[0m
D (2075) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (2086) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (2096) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (2107) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (2117) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x00060000)[0m
[0;32mI (2128) boot: segment 8: paddr=0x000d1610 vaddr=0x50000000 size=0x00008 (     8) load[0m
D (2141) bootloader_flash: mmu set paddr=000d0000 count=1[0m
D (2149) boot: configure drom and irom and start[0m
D (2156) boot: start: 0x40080a7c[0m
heap:182532
tcpip_task_hdlxxx : 3ffcc234, prio:18,stack:2048
I (2463) wifi: frc2_timer_task_hdl:3ffcdc74, prio:22, stack:2048
I (2472) wifi: pp_task_hdl : 3ffd0514, prio:23, stack:8192
I (2473) wifi: mode : softAP (24:0a:c4:05:e2:71)
dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
I (2479) wifi: mode : sta (24:0a:c4:05:e2:70) + softAP (24:0a:c4:05:e2:71)
I (2487) wifi: mode : softAP (24:0a:c4:05:e2:71)
I (485443) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1
I (485444) wifi: station: ac:ee:9e:67:d9:b6 join, AID = 1, n, 20
AT
AT
AT
Any idea what can I do to start communication by AT commands?
