I'm using ledc() to control my servos. I'm using 2 360° servos to replace the motors to make a simple robot.
Lately, I've found that when I set the duty to 0 to stop my robot, the robot still moving. I use some code to print the duty of ledc() after I set it, the number is set to 0, but the servo is still turning which means the duty of the actual squarewave is not updated.
Now I make my code calling ledc() each loop to update the duty to make it produce the physical effect, but this could make the servo control having unstable lag.
I'm using a Servo and an MPU to make my robot head pointing to a fixed Yaw Angle, and this lag of ledc() can't get a good result when the body movement is complicated.
[Maybe Solved]
I can't reproduce the lag now, maybe I used an old version of ESP-Arduino. Don't know if this is solved by a newer version of ESP-Arduino or ESP-IDF.
[Maybe Solved]Lag is found using ledc() to control servo
human890209
