After a lot of research I can't yet fix my issue. I'm trying to update my program including the images inside with OTA.
My program is based on the native_ota_example provided by Espressif and the loboris TFT library for spiffs image.
I have two tasks. One is for download the .bin file contained my program and another task executed first to download the spiffs_image.img file into spiffs partition at 0x002b0000.
My partition table is :
boot: Partition Table:
Label Usage Type ST Offset Length
0 nvs WiFi data 01 02 00009000 00004000
1 otadata OTA data 01 00 0000d000 00002000
2 phy_init RF data 01 01 0000f000 00001000
3 factory factory app 00 00 00010000 000e0000
4 ota_0 OTA app 00 10 000f0000 000e0000
5 ota_1 OTA app 00 11 001d0000 000e0000
6 storage Unknown data 01 82 002b0000 00100000
To download the spiffs_image and write it into spiffs partition , I write this code :
Code: Untitled.c Select all
@brief Task to update spiffs partition
@param pvParameter
static void ota_spiffs_task(void pvParameter)
esp_err_t err;
/ update handle : set by esp_ota_begin(), must be freed via esp_ota_end() */
esp_ota_handle_t update_handle = 0 ;
const esp_partition_t *update_partition = NULL;
esp_partition_t *spiffs_partition=NULL;
ESP_LOGI(TAG, "Starting OTA SPIFFS...");
const esp_partition_t *configured = esp_ota_get_boot_partition();
const esp_partition_t *running = esp_ota_get_running_partition();
/*Update SPIFFS : 1/ First we need to find SPIFFS partition */
esp_partition_iterator_t spiffs_partition_iterator=esp_partition_find(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_SPIFFS,NULL);
while(spiffs_partition_iterator !=NULL){
spiffs_partition = (esp_partition_t *)esp_partition_get(spiffs_partition_iterator);
printf("main: partition type = %d.\n", spiffs_partition->type);
printf("main: partition subtype = %d.\n", spiffs_partition->subtype);
printf("main: partition starting address = %x.\n", spiffs_partition->address);
printf("main: partition size = %x.\n", spiffs_partition->size);
printf("main: partition label = %s.\n", spiffs_partition->label);
printf("main: partition subtype = %d.\n", spiffs_partition->encrypted);
printf("\n");
printf("\n");
spiffs_partition_iterator=esp_partition_next(spiffs_partition_iterator);
vTaskDelay(1000/portTICK_RATE_MS);
esp_partition_iterator_release(spiffs_partition_iterator);
/* Wait for the callback to set the CONNECTED_BIT in the
event group.
xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,
false, true, portMAX_DELAY);
ESP_LOGI(TAG, "Connect to Wifi ! Start to Connect to Server....");
esp_http_client_config_t config = {
.url = SPIFFS_SERVER_URL,
.cert_pem = (char *)server_cert_pem_start,
if (client == NULL) {
ESP_LOGE(TAG, "Failed to initialise HTTP connection");
task_fatal_error();
err = esp_http_client_open(client, 0);
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to open HTTP connection: %s", esp_err_to_name(err));
esp_http_client_cleanup(client);
task_fatal_error();
esp_http_client_fetch_headers(client);
/* 2: Delete SPIFFS Partition */
err=esp_partition_erase_range(spiffs_partition,spiffs_partition->address,spiffs_partition->size);
int binary_file_length = 0;
/*deal with all receive packet*/
while (1) {
int data_read = esp_http_client_read(client, ota_write_data, BUFFSIZE);
if (data_read < 0) {
ESP_LOGE(TAG, "Error: SSL data read error");
http_cleanup(client);
task_fatal_error();
} else if (data_read > 0) {
/* 3 : WRITE SPIFFS PARTITION */
err = esp_partition_write(spiffs_partition,0x0,(const void *)ota_write_data, data_read);
task_fatal_error();
binary_file_length += data_read;
ESP_LOGD(TAG, "Written image length %d", binary_file_length);
} else if (data_read == 0) {
ESP_LOGI(TAG, "Connection closed,all data received");
ESP_LOGI(TAG, "Total Write binary data length : %d", binary_file_length);
ESP_LOGI(TAG, "Prepare to launch ota APP task or restart!");
xTaskCreate(&ota_example_task, "ota_example_task", 8192, NULL, 5, NULL);
vTaskDelete(NULL);
}I get this log error :
E (176) SPIFFS: mount failed, -10025
E (179) [SPIFFS Test]: Failed to mount or format filesystem
I need to run make flashfs to display images correctly.
Thanks a lot for your help
