LEDC low-speed channels not starting?
TinkerBearNZ
Postby TinkerBearNZ » Mon Jul 15, 2019 6:13 am
I've been trying to use (possibly mis-use) the LEDC PWM generators as general waveform generators.
I've run into an instance where setting up 1 high-speed channel and 1 low-speed channel at a low frequency results in no output on the low-speed channel. This has been super frustrating, because I've got similar code that runs fine. It seems to be something to do with starting other channels.
Hacked/reduced version of ledc_example_main.c attached to show the problem.
ledc_example_main.c
(1.41 KiB) Downloaded 702 times
Users browsing this forum: Semrush [Bot] and 1 guest
