Hello !
I've been looking at an ESP32-EVB for the past couple of days and there is a "big" LED on it named LED3, but that is an IR transmitter and I can't use it like a normal LED.
Does the board have some LEDs that I can control ?
I've been looking through documentation but I couldn't find a thing.
I've also looked at this: http://www.barth-dev.de/misc/eqipment/e ... b-pin-map/ .
Does the ESP32-EVB have some LEDs that I can control ?
GeorgeFlorian1
Re: Does the ESP32-EVB have some LEDs that I can control ?
The link you posted bring you to Olimex site. There you can find the schematic for the board.
https://www.olimex.com/Products/IoT/ESP ... e-hardware
I switched one on which also operated the relay to show when my software was running normally. The visual and audible confirmation was useful, but I chose not to send high frequency LED flashes on this pin on this board, but I was only using ESP32-EVB for initial testing.
GeorgeFlorian1
I also did that, but the project I am working on uses those relays to control other hardware. So I can't use those anymore because I will compromise the functionality of the other hardware components.I switched one on which also operated the relay to show when my software was running normally. The visual and audible confirmation was useful, but I chose not to send high frequency LED flashes on this pin on this board, but I was only using ESP32-EVB for initial testing.
GeorgeFlorian1
Yes, and it did not help me.The link you posted bring you to Olimex site. There you can find the schematic for the board.
Ok, well there are only 6 leds on that PCB.Yes, and it did not help me.
DC In Power
Battery Charge Complete
Battery Charging
Battery Power Good
Relay 1A Active
Relay 2A Active
