[TW#12341] BLE characteristics value read/write operations
dperez
Postby dperez » Thu Feb 09, 2017 3:53 pm
I am working on the gatt_server example. I have modified the code to define a 'propietary' (128bit UUID) with a characteristic.
When callin esp_ble_gatts_add_char function:
  • Permisions: ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE
  • Properties: ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_WRITE_NR
Also in "esp_attr_value_t *char_val" parameter y use "&gatts_char_value" that has been defined:
static uint8_t char_value[10] = {0};
esp_attr_value_t gatts_char_value =
.attr_max_len = sizeof(char_value),
.attr_len = sizeof(char_value),
.attr_value = char_value,
My problems are that once connected and discovered the services, the characteristic has the correct length, I mean 10 bytes but its value is not zero.
Also when reading (esp_ble_gatts_get_attr_value(...)) or writing (esp_ble_gatts_set_attr_value(...)) to this characteristic value despite I receive a ESP_OK response from the mentioned functions it seems the write doesn't work because after writing 10 bytes to '11' the value I get when reading is the same that I get at the beginning.
So is there any bug in these functions? Is there any example that shows how to set/get values to characteristics? Any help will be appreciated. Thanks in advance.
Tianhao
Re: BLE characteristics value read/write operations
Postby Tianhao » Mon Feb 13, 2017 8:44 am
We provide two ways to decide the way of sending response by GATT server. One is sent by application by user, and another way is sent by low-layer stack. If use "esp_ble_gatts_set_attr_value", the low-layer stack will store the attribute value. But if you dont't specify low-layer stack send read/write response automatically, even the low-layer stack know the attribute value, it won't send read/write response.
In the demo, this demo will send read/write response by application. So even you call "esp_ble_gatts_set_attr_value", it will not send the value what you set by "esp_ble_gatts_set_attr_value". I will send response by application when received ESP_GATTS_READ_EVT.
In your case, you should set the "ESP_GATT_AUTO_RSP" when call "esp_ble_gatts_add_char" or send response of your "gatts_char_value" in the event_callback functions when received ESP_GATTS_READ_EVT.
dperez
Postby dperez » Thu Feb 16, 2017 11:19 am
Thanks ESP_Tianhao,
Now it is clear!
Once I have set "esp_attr_control_t *control" parameter on "esp_ble_gatts_add_char" function call, read/write operations works ok and autonomously managed.
Without setting this parameter like you said our app has to manage read/write operations with ESP_GATTS_READ_EVT and ESP_GATTS_WRITE_EVT events.
Thanks for your help.
Luca_Guazzaroni
Postby Luca_Guazzaroni » Thu Mar 30, 2017 1:31 pm
HI!
i am having problems with the esp_ble_gatts_set_attr_value function. I setup my service and characteristic by a gatts table and create it with "esp_ble_gatts_create_attr_tab". The thing is that once created the service and characteristic, i cannot change the craracteristic value with "esp_ble_gatts_set_attr_value". I alredy configure the auto responde. Can anyone of you tell me what i am doing wrong?
here the code:
constants declaration:
static const uint16_t primary_service_uuid     = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid     = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid   = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
static const uint8_t  char_prop_read_notify 	 	     = ESP_GATT_CHAR_PROP_BIT_NOTIFY|ESP_GATT_CHAR_PROP_BIT_READ;
static const uint16_t IR_Temperature_svc		= 0xD200;
static const uint16_t IR_Temperature_char_uuid 	= 0xD201;
static const uint8_t  char_CCCD_notify[2] 		= {0x00,0x00};
static const uint16_t IR_CHAR_DECL_HANDLE  = 42;
static const uint16_t IR_CHAR_VALUE_HANDLE  = 43;
uint8_t IR_Temperature_value[] = {0x00,0x00};
attr tab declaration:
static const esp_gatts_attr_db_t IR_Temperature_gatt_db[IR_IDX_NB] =
	// IR Temperature service declaration
	[IR_TEMP_IDX_SVC]       =
	{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
	  sizeof(uint16_t), sizeof(IR_Temperature_svc), (uint8_t *)&IR_Temperature_svc}},
	// IR temperature Characteristic declaration
	[IR_TEMP_IDX_CHAR]  =
	{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
	  CHAR_DECLARATION_SIZE,CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_notify}},
	// IR temperature Characteristic value
	[IR_TEMP_IDX_VAL]   =
	{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&IR_Temperature_char_uuid, ESP_GATT_PERM_READ,
	  sizeof(IR_Temperature_value), sizeof(IR_Temperature_value), (uint8_t *)IR_Temperature_value}},
	// Client Characteristic Configuration Descriptor
	[IR_TEMP_IDX_NTF_CFG]     	=
	{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid,
	   ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
	  sizeof(uint16_t),sizeof(char_CCCD_notify), (uint8_t *)char_CCCD_notify}},
With this code the nRFconnect App detects correctly the service and characterist with the initial value. When i want to uptate de characteristic value, i call
//IR_Sensor_read comes from a uart with other data
IR_Temperature_value[0] = IR_Sensor_read[0];
IR_Temperature_value[1] = IR_Sensor_read[1];
esp_err_t rsp;
rsp = esp_ble_gatts_set_attr_value(IR_CHAR_VALUE_HANDLE, sizeof(IR_Temperature_value), (uint8_t *)IR_Temperature_value);
if(rsp==ESP_OK){
    	ESP_LOGI(GATTS_TAG,"esp_ble_gatts_set_attr_value == ESP_OK\n");
 else{
 	ESP_LOGI(GATTS_TAG,"The ERROR: %d\n", rsp);
but when i check the nRFconnect app, the value not change.
PD: i use the gatt_tab because the application i am developing has 3 services one for R/W, other for Read and the las for Read and notification.
davidtrc
Re: [TW#12341] BLE characteristics value read/write operations
Postby davidtrc » Wed Sep 06, 2017 2:07 pm
Hello, any news?
I have the same problem and cannot find any solution.
Thanks in advance
TVA_VAE
Postby TVA_VAE » Sun Nov 29, 2020 3:16 pm
Same problem here... (with the table example and auto updates).
Users browsing this forum: Bing [Bot], PerplexityBot and 3 guests
